11-03-2016, 07:34 PM | #1 |
757
Rep 1,835
Drives: 2020 X4M CS
Best way to tap into manifold or boost pipe (Pre TB)???
Obviously you could drill into the intake manifold, but obviously that would require removal due to the drill shaving possibly falling into the manifold...
Seems there are no pressurized lines, any hoses running away from boosted parts have one way valves to store vacuum....a I have a boost activated exhaust valve and need a manual boost source
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
11-03-2016, 07:59 PM | #2 |
655
Rep 1,922
Drives: 2011 e91
Drilling into the intake won't get you vacuum since the engine isn't atmospheric. There is a vacuum pump on the engine somewhere. You could tap into the power brake booster line from that pump.
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
11-03-2016, 08:26 PM | #3 | |
757
Rep 1,835
Drives: 2020 X4M CS
If the M3s brake boosted was assisted by boost and not vacuum assisted it be the first car ive heard of in hisory... Dinan has a manual adapter that goes in between your MAP sensor and manifold and has a 1/4 manual boost line to hook a hose too...I need something like that
11-03-2016, 08:28 PM | #4 |
757
Rep 1,835
Drives: 2020 X4M CS
I think you misread and though i said vaccum....To clarify I need boost...
11-03-2016, 08:43 PM | #5 | |
655
Rep 1,922
Drives: 2011 e91
I can't see anything on realoem
2011 E91
11-03-2016, 10:25 PM | #6 |
757
Rep 1,835
Drives: 2020 X4M CS
yea my meth bung which has no vacancy ATM lol.
I found a spot to grab boost pre tb. which should be fine... jw/ if anyone else has needed this and if theres an adapter or easy fix
