Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Summer Tires with Long Lifetime
      11-01-2016, 01:39 PM   #1
Hearf
28
Drives: 2009 E90 335xi
Do you guys have any recommendations for a summer tire with a high treadwear/lifetime? I don't foresee this car going to a track at all so I don't mind if it means giving up a little bit of performance for longevity.
Leaning towards getting a set of Continental ExtremeContact DW
      11-01-2016, 02:55 PM   #2
grovedale
Used Car Overlord
grovedale's Avatar
48
Drives: '09 BMW 335i e93
I have had good luck with Kumho Ecsta all season tires.
      11-01-2016, 03:53 PM   #3
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
MPSS can last a very long time. They have a 30k warranty for square and 15k for staggered. Conti DW don't last nearly as long as PSS. PSS are definitely worth the extra money.
I'd suggest something like a 245/40/18 square for your xi, you'll get a ton of life being awd.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      11-01-2016, 08:24 PM   #4
Hearf
28
Is it 30k for square because you can rotate them? I was curious to see if there are any alternatives for better lifetime.
      11-01-2016, 08:36 PM   #5
Antetokounmpo
1552
Yes. 30k is a ton from a high performance tire... you won't find anything higher without sacrificing a ton of performance.
      11-01-2016, 09:14 PM   #6
LaxIan55
LaxIan55's Avatar
92
Drives: 335i E90 xdrive
I am around 35k on my MPSS, my rears have a couple threads showing but that's due to my camber. I should be able to make it until I put my snows on.
      11-01-2016, 09:43 PM   #7
weehe126
1161
Drives: 2017 340i
I've had pretty good life with my Conti DWs. About to change the fronts and they have 45k miles. I change the rears once a year, about 15k miles.
      11-02-2016, 09:08 AM   #8
FCobra94
Guest
n/a
Drives:
lies! unless your xi is setup for time attack, etc.
      11-02-2016, 10:41 AM   #9
Hearf
28
In about a year, I drive around 26k miles commuting (15% locals, 85% highway). Once my squared stock runflats need to be swapped, I'm planning on making the swap to staggered go-flats + AAA. Keeping in mind that I only use this car for commuting - in your opinion/expertise, is the increased worth the $200 premium for the MPSS with the high mileage that I put on yearly?
I appreciate the help.
Are you running a squared setup on your xi?
      11-02-2016, 11:32 AM   #10
LaxIan55
LaxIan55's Avatar
92
I am 255/35/18 all around which I have loved. The last rotation and my negative camber was too much for the smallest section of tire. They are in the front now and I will probably run a little less camber on the next set.
      11-03-2016, 08:38 AM   #11
FCobra94
Guest
n/a
Drives:
Give us all of your alignment specs. I highly doubt that you're running THAT much camber to thread the inside of your tires.
I'm almost sure your findings are the result of toe, not camber.
      11-03-2016, 12:54 PM   #12
JETmn
245
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
I have 69k miles on my rear PSS and I got 45k out of the fronts(run flats, but fronts are not now). Rears are to the wear bars and will be switched to non-runflat PSS. Awesome tires and all I will use from now on unless I need even more traction. They are very good in that department too.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
      11-04-2016, 06:43 AM   #13
Hearf
28
Square or staggered with your xi? That's really good mileage I think out of PSS from what I've seen.
      11-04-2016, 02:36 PM   #14
YoungBlood
LongDongSilver
274
Drives: e90 335i
I'm running nitto nt555 g2's, and they're great for a sumer tire that lasts a long time, I have 15k on mine, and 4 autocross events and they're still 2/3 tread. They're not the best for autocross, but street they're awesome
