Proper PSI for 19'' wheels and PSS?
10-31-2016, 01:20 PM | #1 |
40
Rep 177
I currently have 18''s with run flats and I run them at the same pressure that the doorjamb sticker says to. What should I run on my new setup?
11-01-2016, 11:30 AM | #4 |
40
Rep 177
11-03-2016, 12:48 AM | #6 |
Where'd my VTEC go?
481
Rep 6,067
Not really. The recommended PSI is fine. Some people like higher PSI because they like the firmer ride. You can run whatever pressure you like as long as you stay somewhere between the BMW recommended and max PSI rating of the tire.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
11-03-2016, 10:09 PM | #8 |
40
Rep 177
I did look into the manual. There's no option for a 235/265 setup. At this time I'm running 36 PSI F/ 38 PSI R. It feels soft but this may be cause I'm so used to RFTs.
11-09-2016, 03:19 PM | #10 |
Kraut Driver
59
Rep 624
Drives: 2014 650i GC/2011 335is DCT
My door jamb with 19" PSS on 225M wheels is like 38F 46R
11-10-2016, 12:39 PM | #11 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
11-12-2016, 09:22 AM | #12 |
25
Rep 114
I think the car feels much better with higher pressure, I like 39f/46r on my as3s. I think with tires with a stiffer sidewall, even non rfts, I would use lower pressures
