New Rims/Tires
10-30-2016, 11:21 AM | #1 |
270
Rep 790
New Rims/Tires
I'll eventually get new rims and tires for my car but 1st want to run it by you folks.
I currently have the stock rims and tires (Bridgestone Potenza runflats) on my 335i xDrive coupe. Current (Stock): Front: 18x8.0 ET34 225/40/18 (Tire diameter 25.09)I'm thinking of going to this: Front: 18x8.5 ET35 235/40/18 (Tire diameter 25.4)I think it'll work from everything I've read. I don't want 19" rims due to the harsher ride quality and tire expense as well. My car isn't lowered but I might do that sometime later but it won't be slammed, just mildly lowered when I decide to do it later. What do you think? |
10-30-2016, 01:29 PM | #2 |
E39
134
Rep 286
You should be fine man. Im lowered on H&R cup kit and run basically your same setup with the exception my rear is ET40. I have zero rub. I have an LCI and I believe I can get by running a 5mm spacer in the rear, possibly a 10mm if I roll my fender.
10-30-2016, 07:26 PM | #3 |
179
Rep 527
Search the threads for rolling diameter of different tire setups. Pretty good chart out there. You need to remain in 1% front to back, and I believe with an xi it's even more important.
10-30-2016, 07:59 PM | #4 | |
270
Rep 790
The BMW all wheel drive system must allow for some slippage between the wheels so I think I'm good. |
10-31-2016, 05:27 AM | #5 | |
1903
Rep 6,968
10-31-2016, 11:43 AM | #6 |
E39
134
Rep 286
A 35 profile in the rear is standard on stock setup. My stock rears were 255/35/18. So going to 265/35/18 added slightly more sidewall anyways. It would be way too much in my opinion to go to 265/40/18
