mmp people i have a question
10-25-2016, 03:51 PM | #1 |
41
Rep 164
guys before i was able to use my tester to check the vacuum leaks but after installing mmp inlets ans outlets i have no idea how to check it
any suggestion
BMS Dual intake system RB PCV Valve BMS Oil Catch Can BMS Oil Thermostat COBB FMIC COBB AccessPort V3 Aerodynamic kit M Package Cp-e BOV Cp-e 3" catless DP Wedge performance stg2 map
10-25-2016, 04:26 PM | #3 | |
41
Rep 164
http://turboboostleaktesters.com/3-series/
Turbo_power4ever93.00 |
10-25-2016, 06:29 PM | #4 |
261
Rep 776
Put one of each of those on the ends of your inlets, where your arir filters used to be. Plug the pcv heater hole on rear inlet. Insert air into system. Listen for leaks.
Google boost leak test n54. |
10-25-2016, 06:51 PM | #5 | |
93
Rep 606
10-26-2016, 03:15 PM | #6 |
41
Rep 164
Will have a look at pcv
10-27-2016, 01:34 PM | #7 |
mTekMods
2157
Rep 2,909
your outlet is probably melted and has a hole in it already.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
10-27-2016, 01:42 PM | #8 | |
41
Rep 164
10-27-2016, 03:07 PM | #10 |
Rep 48
Jesus, move on with your life. You're like a sullen child. If you took all the time you spent complaining and invested it in whatever job you're working, you would have made the money to buy a different set.
Randomaccess33568.50 |
10-27-2016, 04:49 PM | #12 | ||
93
Rep 606
10-27-2016, 04:55 PM | #13 | |||
41
Rep 164
10-28-2016, 10:08 AM | #14 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
10-28-2016, 02:16 PM | #15 |
41
Rep 164
just saw ur reply once i can i will
10-28-2016, 02:53 PM | #16 | |
Rep 48
But to add actual substance to this thread. I have already determined if I have problems with either inlets or outlets, I am just going to cut the problem chunk out and join in an aluminum pipe. |
10-28-2016, 07:04 PM | #18 |
129
Rep 460
or have someone that knows what they are doing install them. Not doing it in the drive way with a brick, a floor jack and a hammer. I installed a set today and its got a ton of clearance.
2020 BMW m5 f90 Project gamma intake downpipes charge coolers . Awe Exhaust Pure_performance_TX stage 3 build motor e40 ABP tune snow performance meth kit
2018 x6m Built motor stage 3 tune PG downpipes |
10-28-2016, 07:16 PM | #19 | |
41
Rep 164
nckwrnr12.00 |
10-29-2016, 02:35 PM | #20 |
41
Rep 164
i dont think its clear but might give u an idea
10-29-2016, 05:17 PM | #21 |
Slow.
3782
Rep 7,151
Did you use a curved pipe? Or just an angled pipe? I assume a straight pipe would not fit given where the manifold can hit the outlet pipe. It looks like it is on a bend.
Did you consider making a bracket to hold the new part of the pipe away? Off the shelf pipe? Or did you just cut a straight 2" aluminium pipe. Did you add a bead to it for clamping reasons? Just curious. I have the same inlets and it's hard to get a good pic without removing the rear inlet pipe. I Appreciate the pic. If you could remove the inlet(you don't have to) we could see the full fix. Thanks man!
11-01-2016, 01:48 PM | #22 |
255
Rep 554
Drives: 2013 335is E93 6MT
Mine split (didn't melt), so I did the same with aluminum pipe and a couple of clamps. First pic is before the split to show the positioning close to the manifold (the heat shield tape is peeling off), second is the outlets with the split, third is post-install directly from the top, fourth is a bit more from the side to show that the outlets have been shortened a bit and now have a downward angle, keeping it well away from the manifold.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
