Newer steering wheel in older model cars?
10-24-2016, 11:02 PM | #2 |
12
Rep 34
I put a newer version in my '07 - pretty much plug n play, but the paddle shifters were a PITA to transfer across. I'd suggest if you can, get one with the correct paddles still in it.
Also, make sure the airbag housing/horn unit is the same size/shape as your existing one if you're planning to transfer it across. I got one with a different fitment, had to send it back to Germany. |
10-24-2016, 11:08 PM | #3 |
Where'd my VTEC go?
481
Rep 6,067
Thats the M Performance steering wheel. It will fit as long as you have the same type of airbag. If you have paddles, you will need to retrofit M3 paddles because that steering wheel was made for the M3.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
10-25-2016, 07:42 PM | #5 |
340
Rep 922
Yup. Basically not worth swapping on a 10 year old car. Sport pack steering wheel is all you need anyway.
2006 330i 6MT Jet Black / Black
10-25-2016, 09:52 PM | #6 | |
40
Rep 80
http://ebay.com/itm/252547168591?_tr...49&_mwBanner=1 I know is not a "newer" wheel but it looks better than stock IMO |
