10-23-2016, 09:09 PM | #1 |
Rep 30
DRL Not working
Hi All,
I am trying to code DRL to work. They currently don't work at all even with the setting in iDrive ticked. So far have changed HU_NBT Daydriving to "Standard". Other options are "perm off" or "perm on". If I modify TFL_MODUS to anything other than off, I get an couple of service warnings. Adaptive headlight failure and lane change warning failure. Option in TFL_MODUS are drl_s, drl_l, drl_h, TFL_s or Off. Is there some other settings I need to change to get DRL to work? I have 8TM fitted to car. Any ideas would be a great benefit. Thanks. Last edited by GDubYa; 10-24-2016 at 03:52 PM.. |
10-25-2016, 04:31 PM | #3 |
2374
Rep 8,364
You have 8TM Daytime Lights by vehicle start inactive?
You want one of these:
10-25-2016, 05:24 PM | #4 |
Rep 30
I have just checked translation for 8TM - "Tagfahrlicht bei Fahrzeugstart inaktiv" which turns out to be "DRL inactive at vehicle start"
This may indeed be my issue. In regards to 8TN or 8TL, can I add these? If so, is that done by VO code? |
10-25-2016, 07:02 PM | #5 | |
2374
Rep 8,364
You can use TM NCD / CAFD Tool to see how those options would affect your ECU's. That way you can FDL code and not overwrite any other existing personalized settings. |
10-25-2016, 09:10 PM | #7 | |
2374
Rep 8,364
Instead, you load a modified FA and use it to VO code. If you are going to FDL code, you need to know which parameters to change. TM's tool will help you with that. |
10-25-2016, 09:13 PM | #8 |
Rep 30
OK Thanks, will get that software and see what I need to do.
You have lost me with the FA and VO code bit. Can you please explain in a step by step process. I know how to change 8TM to 8TN in SALAPA. What happens next, do I save the FA file to desktop? Then what? Appreciate your help so far. |
10-27-2016, 03:21 AM | #11 |
2374
Rep 8,364
07-31-2018, 08:41 AM | #12 |
Rep 1
Hello! Can someone help me? I bought a F30 320i Sport GP but DRL (angel eyes) don't turns on when i startup the ignition / engine. DRL (angel eyes) Only works when low / high beam is on.
I have the option to switch on / off DRL in iDrive but not work when i check the option. And idrive shows that the vertical adjustment of the headlights does not work. I have Esys cable and softwares to code the car. |
07-31-2018, 07:14 PM | #13 | |
2374
Rep 8,364
03-06-2023, 02:26 AM | #14 | |
Rep 5
