Oil leak
10-23-2016, 11:03 AM | #1 |
Rep 27
Oil leak
Hi all,
I changed my oil about 2-3 weeks ago and when I did that I saw an oil leak. I cleaned all the oil out really well. Last night I got under the car again and saw the oil leak again. I brought it to a dealership for an inspection and they told me they had to replace the oil pan gasket. Total cost with labor and parts is $1,400. The car isn't leaking onto the floor or anything it's just a small drops of oil on the plastic panel under the car. Is it worth paying the 1,400 dollars just for a small oil leak or just add some more oil more often? |
10-23-2016, 11:25 AM | #2 | |
413
Rep 1,362
Oil change, had oil all over my pan so used my zepp degreaser and clean everything up. That was like a 2 month ago and is looking the same way i was before. And i have a VCG leak.
10-23-2016, 05:20 PM | #4 |
1903
Rep 6,968
I did this DIY in June. You will need a buddy to help you put the oil pan back into place. You will also need a small torque wrench and an Engine Support Bar.
It takes about 8 hours to complete this DIY. It absolutely looks like the oil pan gasket is leaking. I agree with the above poster in that you should check the Valve Cover gasket, especially on the firewall side. you need to use a mirror with a light on it. Craftsman makes one. Search this forum for DIY's you will find a few. I had a nice write up, if your interested. The only oil leak you'll probably have to pay for is the Rear Main Seal. |
10-23-2016, 07:26 PM | #5 |
54
Rep 297
In april the dealer did my VCG, OFHG and OPG all in one shot. $4500 worth of work, Cost me $50 bc of extended warranty.
F22_Raptor118.00 |
10-23-2016, 11:40 PM | #6 |
Rep 35
I had a oil pan gasket leak at 130k because many of the bolts holding the pan on were extremely loose, like not even finger tight. I noticed because of drops on the floor and the engine above the gasket line was extremely clean. I just tightened up the bolts using a universal joint socket and an open end wrench for a couple of the hard to reach ones. It's possible to reach every bolt with a little patience. Solved my problem completely. Long term I might need a new gasket, but for now I'm just planning to monitor the situation and will check the bolts every 6 months or so.
Bluewater328iT86.50 |
10-24-2016, 12:17 AM | #7 | |
Rep 27
10-24-2016, 01:23 AM | #8 | |
2188
Rep 5,002
