E90 Upper Windshield rubber trim replacement
10-23-2016, 02:41 AM | #1 |
895
Rep 3,141
My upper windshield trim is cracked, and starting to crumble. I watched a lot of online videos on how to replace the trim, and it looks simple. However, I'm afraid if I try to replace it myself, I'll somehow screw it up. Is it that easy to replace, and how many of us actually did it themselves? It looks extremely easy on the YouTube videos. Also, what did you use to clean the surface before installing the trim piece? Thanks...
10-23-2016, 03:40 AM | #2 | |
276
Rep 655
10-23-2016, 04:03 AM | #3 |
276
Rep 655
10-23-2016, 09:10 PM | #5 |
223
Rep 1,073
Its very simple. My best advice is to slide the passenger and driver side into the channel and use a soft rubber mallet to seat the remainder of the weather stripping into place.
10-24-2016, 03:29 PM | #8 |
111
Rep 529
Are they both pretty straight-forward DIY? The back looks a lot more complicated.
2011 335d Deep Sea Blue on Beige (stock except for the cheap ass wheels from PO)
2010 328i Tasman Green on Saddle (stock) |
10-24-2016, 04:04 PM | #9 |
douchebaggo
186
Rep 972
10-24-2016, 08:47 PM | #10 |
276
Rep 655
10-24-2016, 08:54 PM | #11 |
380
Rep 1,497
Very simple to do.. Buy the gel goof off. Will help remove the old baked in rubber. Clean it all well, than use rubbing alcohol to clean all the channels where the new stuff will cover.. Let it dry really well. Than depending on what kit you get, apply the side first and work your way from bottom to top corners on each side first, than from middle to outside corners on the top. A rubber malet will help out a alot when it comes to seating it right. I have done 6 so far and always came out perfect
mantis276.00 |
10-24-2016, 09:30 PM | #12 |
43
Rep 301
yeah i replaced mine in under 30min. Most of the time was spent cleaning the residue and getting the old strip off. there are plenty of youtube videos on how to do it. I think I lined up both ends first then worked towards the middle. Use a rubber mallet or bottom of your fist.
10-25-2016, 11:49 AM | #13 |
164
Rep 598
No need to be worried about trying. The only thing you could do to screw up is crack the windshield if you pry on it with a screwdriver or something while trying to get the old rubber out. If for some reason you start but cop out and don't finish, then just take it somewhere.
But yeah, it's easy. Hardest part is digging out the old rubber and getting to surface clean. |
10-25-2016, 12:30 PM | #14 |
263
Rep 1,225
Had it replaced on mine this past summer. Didn't have time to do it myself so my trusted mechanic did it for me. Only cost $75 for the part and labor.
Good luck to you!
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner 1997 Toyota Corolla 1983 Mercedes Benz 380SL Roadster |
