E92 very rough idle
10-21-2016, 01:51 PM | #1 |
48
Rep 104
Drives: Monaco Blue 335i
E92 very rough idle
Hi everyone,
I recently did a valve cover gasket change, and car started right up just fine. However, in the past few days, now it's been having an incredibly rough idle, and just a rough idle, the revs smooth out and you feel no misfire at higher rpms. What could be a possible cause for this? I'd rather not redo the valve cover gasket if possible Thanks in advance!
Current: 2006 330i Mystic Blue 6MT, 2011 328i Coupe Titan Silver Ex: 2006 330i Barrique Red, 2008 335i Monaco Blue, 2011 335i Deep Sea Blue |
10-21-2016, 02:05 PM | #2 |
48
Rep 104
I just plugged in the code reader and I basically have a misfire in all cylinders, and on top of that it says coolant temperature sensor, measurement . Not sure what could be wrong as the valve cover is sealed and I haven't been losing oil!
buckhorn74.50 |
10-22-2016, 12:53 AM | #3 |
1857
Rep 2,554
You pulled a lot of electronics and every plug and coil so perhaps a lose connection somewhere? Also I'm thinking it could be something with the valvetronic motor but I'm almost positive that when you turn on the ignition without starting the car it auto adjusts back into place.
10-22-2016, 09:15 AM | #4 | |
48
Rep 104
10-22-2016, 08:42 PM | #6 |
48
Rep 104
The grounds are in place, connected. I'm starting to give up, I removed and re-installed the valvetronic motor, looked ok to me. The car now idles very rough for maybe 30 or so seconds then I think the engine adjusts and the rough idle goes away, albeit with a low (500-550rpm) idle speed.
10-22-2016, 09:50 PM | #7 |
1007
Rep 2,108
One other thing possible, some section of the valve cover gasket rolled over and pinched during installation causing vacuum leak. It is not uncommon to happen. Check all around the valve cover to verify the gasket is in correct position. An inspection mirror will help to see. But it would also have some small oil leak in the area if this happened.
10-22-2016, 09:56 PM | #8 |
223
Rep 5,120
Check your valvetronic sensor. There is usually oil inside the connection when they go out. I would think it would give you a different code for that, but it's worth checking.
10-22-2016, 10:36 PM | #9 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Are the only codes you're getting is misfire? Nothing about your o2 sensors/running lean or anything? Had the dealer replace my vcg under warranty and 'coincidentally' my rear o2 sensor went bad causing misfires
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
10-23-2016, 01:18 AM | #10 | ||
1857
Rep 2,554
11-11-2016, 04:13 PM | #11 |
48
Rep 104
Interestingly enough, I switched two of the wires that were clipped to the fuel rail next to the intake manifold, and now the car runs much smoother than before. Theres still a slight roughness to the engine, but I think its because the car has been sitting for close to a month now. I still feel that its not back to its original smooth running though. I removed and reinstalled the valve cover as well. Not sure what could be happening. Code reader just shows misfire and electric coolant pump malfunction, but Check engine light is off for the time being.
05-22-2019, 05:05 AM | #12 |
480
Rep 1,600
Old thread but switching the o2 sensor connectors will cause the engine to run like that. The N52 has a specific code when this happens and it is capable of detecting a swtiched o2 sensor conection
