oil viscosity
10-20-2016, 11:32 AM | #1 |
17
Rep 120
oil viscosity
Hello, I have BMW e90 325i n52 sedan, and I have to add 1liter/quart of oil every 400miles/600km
I'm wondering if the oil consumption can change if I use different kind of oil brand/viscosity? Currently using 5w-30 fully synthetic Been searching about the oil viscosity and what it means but haven't found anything :S I live in kinda cold climate country. |
10-20-2016, 12:15 PM | #2 |
263
Rep 1,225
Having to add 1L of oil every 400 miles/600kms? That's highly unusual to lose that much oil in such a short mileage distance so you must have some kind of leak somewhere. Changing the oil viscosity can affect oil consumption, but not by how much you are having to add. Someone correct me if I'm wrong. You are already using 5w-30 fully synthetic which is the correct oil so you should have your engine checked for worn seals and gaskets especially if it has high miles.
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner 1997 Toyota Corolla 1983 Mercedes Benz 380SL Roadster |
10-20-2016, 12:19 PM | #3 | |
17
Rep 120
I looked up gaskets and seals replacements and they aren't that expensive in US ? He said lowest price would be 500 euros and it can only go higher depending on the problem. That's weird. And also to note he just checked if there's no leaks, there wasn't. So the oil is getting in the engine and being burned most likely. |
10-20-2016, 06:43 PM | #4 |
392
Rep 2,367
Drives: 2011 335i
U must hav a typo or a major leak
10-21-2016, 05:56 AM | #5 |
17309
Rep 18,733
I think you need to do a compression and leak down test to confirm the health of the cylinders. If they are all close to specification, then look at the oil separator, it may be broken and allowing oil to get into the intake an thus being burned during combustion.
Good luck with it.
10-21-2016, 08:33 AM | #6 | |
193
Rep 666
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
10-21-2016, 08:44 AM | #7 |
Cometh
1090
Rep 1,305
Drives: Boy's Soul
I think oil viscosity is the least of your concerns if you are topping off 1L every 600km. To answer your question, though, I would use a 0w40 A3 oil with LL01 spec preferably.
10-22-2016, 09:31 AM | #8 |
392
Rep 2,367
Drives: 2011 335i
What should the oil level be when it needs a quart when using a obd2 to check?
