Oil smoke from under the hood
10-20-2016, 10:43 AM | #1 |
16
Rep 72
Hi all,
In the past month or so, I've been having puffs of smoke come from under the hood when I'm stopped at a light. Seems to be most obvious after I get off the freeway, but probably because I don't do much around town driving. I replaced the Valve Cover Gasket, and there was no difference in the smoking. I have visualized the perimeter of the cover since I changed it, and its still clean. I put the car up on ramps, and tried to poke around underneath with the bottom panel off, and its really hard to see very much under there. I DID, however, see what is probably repeated drops of oil dripping from the front turbo V-Clamp. I couldn't find a spot on the pipes that looked like burnt oil, though. I am ready to replace the Oil Filter Housing gasket, which is clearly leaking, but I wanted to go ahead and post the question here to see if there is any wisdom about this, because I have my doubts that the OFHG would result in oil dripping onto the manifold/downpipe. I was also resigned to replace the turbos, but since they still push hard, I figured I would try to more closely diagnose the smoking issue before diving in to replace parts. I tried my hardest when I was under the car to inspect the whole exhaust manifold/downpipe area, but it was very tight and I could hardly see anything. 2008 335i, DPs, 120K miles, I believe original turbos that have a good rattle but still push 15 psi, loses a good bit of oil, but none on the ground. Thanks for any insight!!
JB4, DPs, Style 313 wheels, M-Sport front bumper, Inlets, DCI
10-20-2016, 01:34 PM | #3 |
16
Rep 72
Thanks for the reply. I did inspect it closely when I replaced the gasket recently. Unless it can leak from a hairline crack, I think I ruled out a cracked cover.
I will, however, take a close look again for signs of fresh oil around the cover. Any other thoughts?
10-20-2016, 02:04 PM | #4 | |
654
Rep 946
10-20-2016, 02:17 PM | #5 |
140
Rep 476
The gasket could potentially be installed incorrectly. If you cleaned around the plugs and injectors when installing the gasket I would look for freshly pooled oil. This to me would be a sign that there's a crack.
One other possibility is the seal on the oil fill cap has degraded. |
