2013 328xi Engine Failure at 55k Miles
10-19-2016, 05:02 PM | #1 |
Rep 2
Hi all,
Wanted to come on here and share my story with you. It was a big lesson for me, so hopefully someone else can get something out of this. Purchased my 2013 328xi used wtih 34k miles from a private dealer, still under warranty. First BMW, and first car I have ever purchased for myself. Serviced it properly based on the cars notifications at a local BMW service center. Last service was at 49k miles and everything was checked out, oil changed, multi-point inspection, etc. Two weeks ago, driving off a highway exit ramp (car at 55k miles) I received a red engine oil pressure low, followed by yellow drive train malfunction. As I came to a stop at the end of the ramp the car put itself in park and shut off. Was not able to get it back on or even into neutral. I was finally able to get it taken to my BMW Service center who informed me the entire engine would need to be replaced. Specifically got, "REMOVED VALVE COVER FOUND INTAKE VANOS UNIT BROKEN AWAY FROM CAMSHAFT ALL OF THE CHAIN GUIDES BROKEN AND THE INTAKE CAMSHAFT IS SEIZED. REMOVED NUMBER THREE BEARING CAP FOUND HEAVILY SCORED AND METAL AROUND CAP. ENGINE SUFFERED TO MUCH DAMAGE TO REBUILD ENGINE WILL REQUIRE REPLACEMENT. QUOTE IN SG. OIL SERVICE AND EVAC AND RECHARGE REQUIRE WITH REPLACEMENT." This came to over $18k, effectively totaling the car in my opinion. I requested a goodwill replacement from BMW but was denied due to poor oil history. The car had its oil changed every 10k miles (BMW recommends 15k for this car), however the carfax shows no service record prior to 25k miles. In essence, they denied my goodwill replacement because they deem that no oil change occurred for the first 25k miles leading to this issue 30k miles later. The carfax doesn't show the name of the first owner, nor will BMW give it to me so I am unable to reach out and find out if anything was ever done. I reached out to the original dealership who sold the car to see what they might be able to provide but haven't heard anything back yet. Likely will need to go for a used engine at a 3rd party shop or maybe just sell the car for parts. I loved the car, but can't ever justify purchasing another BMW after this. I suppose the moral of the story is to check the carfax not just for accidents and major issues, but for simple oil changes as well. And change your oil much more frequently then BMW recommends. |
10-19-2016, 05:27 PM | #2 |
193
Rep 666
That's tough. BMW has the ability to see if the oil has been changed at a dealership; I would ask them to look up the car's internal service history. Engines for your car are inexpensive at around 1-2k. You may be looking at a 4k repair if performed at an independent shop.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
10-19-2016, 05:41 PM | #3 |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
Any BMW dealer should be able to provide maintenance/warranty work performed at any BMW dealer by giving the last se7en digits of the VIN. Gonna pull a Mike Miller here but speak to the service manager. GL.
10-19-2016, 07:48 PM | #4 |
52
Rep 191
Hey mate. Sorry about your unfortunate news. Dealerships can be scumbags sometimes I wouldn't expect to get help from them. There is a shop in NJ called project M Motors. They have SEVERAL salvage parts such as replacement engines. Look up projectmmotors on facebook or instagram best of luck
10-19-2016, 10:01 PM | #6 |
17315
Rep 18,737
You have no idea if the oil service history caused the engine failure or not. It sounds like the oil pump broke. The inspection report mentioned nothing about oil sludge found in the engine. Oil sludge is what causes lubrication failures in engines because the sludge blocks the oil passages and starves the bearing surfaces of oil.
All BMWs sold sine 1996 come with "free" maintenance during the warranty period. Unless the previous owner(s) were complete dumbasses, the car would have seen at least 2 if not 3 oil changes provided by BMW free of charge, which would be in BMW's service database. Whether they got reported to CarFax is a different issue. The engine should still be under warranty. How do you know the car has oil changes every 10,000 miles if BMW can't establish it that it didn't have an oil change until 25,000 miles? You should demand that BMW show you what service records it has for the car. You have a right to see them. BMW can not allow you to see the original purchaser, but that is easily to redact from the records print out.
10-20-2016, 08:54 AM | #7 | |
164
Rep 598
Why on earth is BMW relying on Carfax records? UNLESS... BMW actually has no record of oil changes at any of its dealers, then it would look to Carfax to see if an independent shop reported an oil change. Failing both of those, it would be reasonable to assume that oil changes weren't done. BMW dealers are not obligated to share the service history of your car with you. They consider the information to belong to the previous owner, and the right to that information does not convey to subsequent owners. However, you may find a service advisor who will look it up for you. Instead of calling the original dealership (or even your own), just walk in, go to a service advisor, give them your key and ask if they can verify the service history. You may have better luck if you don't just flat out ask for a printout, but if you just ask them to look and see what oil services were done. Mine gladly looked up the history on my car. She said in her opinion, I should have the information since it's my car. |
10-20-2016, 10:59 AM | #8 |
78
Rep 739
Jesus that's horrible, but you can find used/rebuilt n52s and n51s for 1.5k to 2k with 50k-80k miles and right under 3k for motors with less than 45k.
18k is what my friend paid to get a 29k miles s65 after his m3 went to shit.
2009 Alpine White E92 N51 328i Automagic | Premium & Sport Pkg. | Coral Red/Black Dakota Leather Interior | M-Spor | BMW Performance Exhaust | Active Autowerke Headers | BBS CH-R | CPS Front Lip | Performance Front Grills | 888Concepts Custom Headlights (GONE)
2011 Alpine White E90 N55 335i Automagic |
10-20-2016, 12:52 PM | #10 |
285
Rep 615
Drives: '11 E92 335xi 6MT
Carfax service history is nice but there are way too many shops that don't report to Carfax for it to ever be truly comprehensive.
You were probably quoted the cost of a brand new replacement motor. Look into BMW remanufactured motors. They have a 2 year warranty from BMW and usually are more like $4-5k instead of $18k. |
10-20-2016, 01:03 PM | #11 |
103
Rep 199
If you explain this to your dealer I dont see why they would neglect to give you the maintenance history. BMW NA denied your goodwill? I would assume that means they can see the maint history?
Also where did you see an oil change every 10k? |
10-20-2016, 04:38 PM | #12 |
Rep 2
Thanks everyone. I was able to get the service history from a different BMW rep. No history of an oil change with a BMW listed prior to 25k. I was able to see the oil change history on the carfax from previous owners.
I was able to get the second owner of the car to reach out to the first owner (they wouldn't tell me the name, only that they were a company). Whoever the first owner was refused to provide any documentation. I did talk to others who informed me that having 3 oil changes after the first missed oil change should have cleared out the sludge and it is unlikely that the missed oil change caused this problem. Efthreeoh makes an interesting point, the tech report does not mention any mention of oil sludge. Nothing of the sort was brought up until they discovered the missing oil change. |
10-20-2016, 06:20 PM | #13 |
2188
Rep 5,002
If no bmw coverage then go to an independent shop. They can install a used motor ($1.5k) for about $2.5-3k.
Sorry to say but without documentation Bmw will not replace anything, honestly given your warranty expiration I doubt they would even if you had the documentation Extremely rare failure of an n52. Sorry to hear. Hope you're able to get it sorted quickly and cheaply. |
10-20-2016, 07:31 PM | #14 | |
147
Rep 500
10-20-2016, 07:33 PM | #15 |
2188
Rep 5,002
10-21-2016, 11:09 AM | #16 |
87
Rep 471
In 2013, the coupes were E90 and the sedans were F30. OP does not specify which engine he has, but an engine failure is rather rare on either one.
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows |
10-22-2016, 06:01 AM | #17 |
17315
Rep 18,737
OP, from what you describe how the failure occurred, it looks like to me the oil pump failed. You noted the low oil pressure light came on first, then the engine basically shut down. If your engine had sludge in it, several oil changes probably would not have totally cleared it up and there would be evidence of sludge still in the engine. You bought the car at 34,000 miles and drove it 20,000 miles before the problem came up. If the engine had sludge in it because it didn't see the first oil change until 25,000 miles, the engine would have died a lot earlier than 20,000 mile after you bought it. If the engine saw it's first change at 25,000 I doubt it did any real damage, but I suspect the engine had an oil change that for some reason wasn't recorded. A scan of the ECU will tell you how many oil changes there were if the CBS was reset every the oil service was done.
I think the oil pump failed and BMW is using the excuse of lack of maintenance records to not repair the engine. BMW makes it extremely clear that new BMWs under warranty are subject to "free" maintenance for the first 4 years and 50,000 miles of ownership. The selling dealership constantly reminds the owner that the car is due for service, they send mailers all the time. And the CBS would have made it clear the engine was far past due an oil change (the first one). I'm not absolutely sure, but seems to me the ECU should have a record of the the CBS reporting engine oil past due. Hassmaschine is the expert on the ECU, maybe he knows for sure.
Bluewater328iT86.50 TBN54426.50 |
10-22-2016, 10:18 AM | #18 | |
108
Rep 474
10-22-2016, 11:42 AM | #19 |
3821
Rep 4,660
Drives: BMW
While we're on the subject, while BMW could use the lack of maintenance records as a sign of neglect can they solely base their decision on that? Say the original owner(s) did the oil changes themselves out of pocket, never went to BMW for maintenance and never updated CBS so maintenance was in fact done but was never properly reset and recorded through any system, I don't think it makes sense to form a conclusion just because records were missing without any sort of physical evidence that indicates there was a lack of maintenance done.
