Caster/Camber Plates to Reduce Tire Wear
10-17-2016, 05:18 PM | #1 |
1013
Rep 1,268
Has anyone install Caster/Camber Plates on a 335I to help reduce the inner tire wear. I mostly use my 335I as a daily driver and I am getting tired of replacing tires once every 18 months of so (15K to 20K miles). As we know the alignment shops can not help, there is no way to get rid of the negative camber on the 335I unless you change the suspension. I figure the most affective way to do this is a caster camber plate and if I want to track the car in the future I can put in the camber I need and then take it back out.
Is someone has done this, which plates would you recommend using. Ideally I am looking for something which does not require much modification to the actually car like drilling holes and such. |
10-17-2016, 07:32 PM | #3 | |
20
Rep 106
10-17-2016, 08:19 PM | #4 |
181
Rep 657
I am also interested in this....
Also OP you might try posting in the suspension thread. Plenty of people willing to help there with this issue. |
10-17-2016, 08:37 PM | #5 | |
1013
Rep 1,268
10-18-2016, 12:12 AM | #6 |
Where'd my VTEC go?
481
Rep 6,067
A camber plate will definitely let you adjust camber back to within stock specs.
But it's weird that your camber is that high up front, assuming your suspension is stock. It means something is probably damaged or bent. Also, inner tire wear is most of the time caused by improper toe, not camber. Toe will wear just the inner edge of the tire. Camber will wear across the whole tire in a uniform sloping manner.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
