XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
      10-02-2016, 07:33 PM   #1
Carlin/14/E84
14
Drives: 2014 x1 bmw
Thermostat
My 2014 s28i throw a 'Service Engine Soon' yellow light, I scan to see what it was and the OBDII gave me a P0597 reading as follow: Thermostat Heater Control Circuit Open. Has anyone had this problem with the thermostat? I was going to buy a thermostat and R&R the bad one, but probably I should take the car to the dealer first just in case it could be something more than the thermostat my OBDII scanner is a generic type. The car mileage at the present time are 58,000.
OK, I did go to the Dealer, even though I removed the SES light from the dash with my 'Generic' scanner. The rep. did mentioned that BMW do have an issue with the thermostat, also they do have a back order, but he said the thermostat do function like it suppose to except is always open, and it does give a fault to the ECU. I asked about a recall on the part, he didn't know. I inquired how much it will cost for the shop to hook-up their scanner and troubleshoot the problem, $175.
Anyway, I did order a thermostat not thru the Dealer, $72. The best part of all this in November of this year the car is scheduled for the re-call airbag to R&R.
      10-02-2016, 08:33 PM   #2
vstolpner
25
Drives: 2019 F39 X2 m35i
I've heard a few people having bad thermostats, so might just be that.
I'm assuming you're out of warranty, so consider going to an independent shop instead.
And depending if you have a generic OBD scanner which can't read the BMW specific codes, then think about getting one that can. I've had good luck with Carly over Bluetooth to an OBD adapter.
      10-03-2016, 08:15 AM   #3
kiloTHREE
76
Drives: '13 xDrive28i
Good luck, those thermostats are perpetually back ordered.
      10-03-2016, 09:50 AM   #4
Carlin/14/E84
14
Drives: 2014 x1 bmw
Yes, out of warranty long time ago, plus I do all the maintenance and any add to my car. I checked other forums and it seems is not a fluke case BMW do have a problem with that specific thermostat.
I'll consider to buy a better scanner to support the X1.
      10-03-2016, 10:03 AM   #5
Carlin/14/E84
14
Drives: 2014 x1 bmw
I think you are right, I checked with the realoem catalog, and the thermostat has been superseded many times.
I'll go to the dealer and find out if is a recall on the thermostat if not how much for the fix, and when my airbag is scheduled to be install.
      10-03-2016, 11:53 AM   #6
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
I received mixed information from different bmw representatives about the thermostat being volunteer recalled. Mine was replaced recently. Told them i need it to pass smog check for registration.
      10-03-2016, 01:30 PM   #7
Carlin/14/E84
14
Drives: 2014 x1 bmw
It was replaced at not charge?
      10-03-2016, 01:52 PM   #8
d1saster
Bulgaria
60
Yes but I'm still under warranty. You should check with BMW first if there's a recall.
      10-04-2016, 09:24 PM   #9
kurtthewurt
kurtthewurt's Avatar
Drives: '13 X1 sDrive28i, Mineral Grey
There's definitely an issue with the thermostats. My '13 sDrive28i threw a P0597 code a few weeks ago, so I took it in to the dealer and they replaced it. The woman at the SA desk next to me also had a broken thermostat that was getting replaced.
(FWIW, the code popped up at about 61k miles, and was covered under my 6yr/100k mi Extended Service Contract for a $50 deductible. It's a $500 repair if out of warranty.)
      10-05-2016, 11:05 AM   #10
Carlin/14/E84
14
Drives: 2014 x1 bmw
OUCH! $500...Strong reason I'm doing the R&R my self. Thanks for the info, hope it will be a recall at the near future.
xbimmers
