What oil do you use?
09-17-2016, 02:53 PM | #1 |
660
Rep 780
For you guys running higher hp what oil do you run? I know there are threads on this topic already but most are years old so I'd like to see what's been lasting for most people! I still run 0w40 and I'd like to run 5w40 or 10w40
09-17-2016, 03:45 PM | #4 |
162
Rep 422
Drives: F87 M2 DCT, F15 X5
Tracked a E90 FBO N54 car. Oil temps hovered around 260 for at least 20 minutes. UOA showed perfect wear pattern after 3,000 miles on Mobil 1 0w-40.
Given the M1 doesn't rate BMW LL-01 anymore, I would switch to Castrol 0w-40 because it's the same price and availability as M1 was. |
09-17-2016, 04:37 PM | #6 |
654
Rep 946
Oil is definitely not all the same. The base stock may be similar, but the additives will vary. It depends on what you want to spend, but LiquiMoly and Motul are two of the better brands that you probably won't find in stores.
STR8-6IX536.00 |
09-17-2016, 04:43 PM | #7 | |
660
Rep 780
https://www.amazon.com/Motul-007250-.../dp/B004LEYIQ8 |
09-17-2016, 04:51 PM | #8 |
660
Rep 780
09-17-2016, 07:45 PM | #14 |
654
Rep 946
I'm thinking of switching from LiquiMoly to Rotella T6 due to convenience. Did you guys notice any changes with Rotella vs what you ran before? When I switched from Castrol Edge to LiquiMoly, my oil consumption dropped.
09-17-2016, 08:13 PM | #15 |
105
Rep 544
Yes, my oil consumption was less and my lifters quite down a lot. I used Mbile 1 and will never use that oil again.
09-18-2016, 02:38 PM | #21 |
648
Rep 2,011
Nothing special. Its a diesel oil, not ll01, thicker when cold, but cheap and easily available.
335i e92 TPC 19Ts
BeastMode335i1130.00 |
09-18-2016, 03:00 PM | #22 |
421
Rep 1,643
Motul 8100 xcess 5w40. Anecdotal observations indicate it may have lowered the time it takes for my oil to fully warm up, and keeps it at a slightly cooler temp.
2007 E92 335i MT
