What fixed your Limp mode under WOT issue?
09-13-2016, 05:08 PM | #1 |
423
Rep 900
This is an attempt to create a "database" of fixes for Limp mode issue occurring under Wide Open Throttle. The data will be a goldmine for folks chasing this issue needing to just reference the list of possible fixes, kinda of a check list to run down through.
Please just list what finally fixed the limp mode. No long stories and narrations etc. Just a summary. Thanks! Last edited by musa; 09-13-2016 at 10:16 PM.. |
09-13-2016, 06:24 PM | #2 |
140
Rep 476
4th gear getting on the highway I hit limp mode. 30EF. Fixed with new vacuum lines and boost solenoids.
SaugaSoul924.00 PNWBimmer657870.50 |
09-13-2016, 08:26 PM | #4 |
406
Rep 574
ritzzzzzwik232.00 PNWBimmer657870.50 |
09-14-2016, 03:35 PM | #6 |
453
Rep 2,973
Old plugs with a tune will send you into limp mode under WOT or significant load.
Change plugs as the first debug.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
09-14-2016, 08:18 PM | #7 |
163
Rep 466
As soon as I got a tune every time I went wide open throttle the car would go into limp mode. A walnut blasting /cleaning of the intake valves fixed everything.
2007 e90 335i
pure stage 2 DD turbos, rb inlets Last edited by Riceball777; 09-14-2016 at 10:16 PM.. |
09-14-2016, 08:33 PM | #8 |
192
Rep 1,173
Yea. Seems i get 15-25WOT and bam. Back to limp.... 10 of those WOT is wasted on logging ... ill be doing walnut blasting and hopefully i get 30WOT before misfires #dead
09-16-2016, 03:47 PM | #9 |
335 Newb
Rep 28
New Turbos! Seriously, I replaced vacuum lines, a cracked valve cover, tightened up charge pipe, etc. and finally determined that my front turbo wastegate was stuck open. The actuator wasnt moving when testing with vacuum. Dealer replaced both turbos under the BMW field notice/extended turbo warranty. No more 30FF for me.
feuer4275.50 |
09-18-2016, 03:04 PM | #10 |
421
Rep 1,643
Let's see...one time it was a separated fmic pipe, another time it was a not fully seated cp connection at the tb, a few times it's been plugs or coil packs, twice its been vanos Solenoids, two times it was hpfp related, once it was lp sensor, yet another time it was vacuum lines, oh and then another time my dme got fried...this is all from 38k to 130k miles.
2007 E92 335i MT
09-18-2016, 03:34 PM | #11 |
93
Rep 605
the only time I had limp mode at WOT was about a year ago. it gave me codes stating injector shutoff. I ran fuel injector cleaner twice with two fillups of gas and then I bought a hpfp cuz I thought I needed it, but I was lazy and months passed and before I installed the hpfp I noticed I would go WOT and no more limp mode so I returned the hpfp. recently I turned up the boost to 19psi and no issues. I wonder if the fuel injector cleaner actually did anything or not?? but worth a try I guess.
09-18-2016, 04:05 PM | #12 |
71
Rep 648
Drives: 2012 335is
A step colder spark plugs
2012 E92 335is | BSM/Coral Red | Moonroof Delete | 6MT BQ Tuning | ar design DPs | M Performance Spoiler | Michelin PSS | Cyba Ram Air | VRSF CP | Fuel-It! Stg 2 LPFP Split Armrest | LUX Reverse Lights | Rear Fog Lights Enabled TOOK DELIVERY 24 OCT 2011 [FIRST PICS] [INTERIOR PICS] |
09-20-2016, 03:44 PM | #14 | |
117
Rep 143
I had intermittent 30FF and when modifying my turbos to Stage 2 workshop checked actuators and both of them were leaking, one a bit and the other much more. Replacing them with new units fixed all 30FF issues (and new turbo made me smile a lot!) |
06-13-2017, 07:32 PM | #15 |
423
Rep 900
Finally got it fixed by replacing the DME. After the fact I learned that reflashing the DME at the dealer would probably have fixed it too. The car runs fantastic now - not just the WOT is completely gone but the overall performance of the car has improved aplenty.
The error code was always 5E19 - DSC CAN DME/DDE Torque Reduction Not Possible;engine torque not adjustable. |
06-14-2017, 10:19 AM | #17 |
47
Rep 128
06-16-2017, 10:26 PM | #19 |
4542
Rep 11,903
O2 sensors
06-17-2017, 07:49 PM | #20 |
48
Rep 162
Mine would only go into limp.mode when in sport mode. Regular D was perfectly fine. Cleaned out my exhaust vanos since I was getting that code. So far so good
08-17-2017, 08:26 PM | #21 |
Rep 19
Boost solenoids
Suffered from 4 years of track limp modes, solved with new boost solenoids. Walnut cleaning did not hurt.
Limp is back with ABS pump failure - occurs under heavy turn one breaking followed by WOT toward track out. Hope ABS rebuild solves problem. |
