09-13-2016, 09:15 AM | #1 |
741
Rep 2,511
How many miles until your first warrantee visit?
Just sat in the service reception while BMW try and figure out my rapidly flashing "Clowns Nose" with just over 200 miles on the clock!
Hopefully a quick and simple fix... Usual home checks done, doors Windows etc... But, they've had the car over an hour now... :-/ What's the shortest distance you good folk have managed before an issue surfaces?... On the plus side, the 40i sounds fantastic from outside the car also. Just had to watch it started up and driven away. Hopefully not for too much longer...
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
09-13-2016, 09:40 AM | #2 |
8456
Rep 8,783
Oh no, that's bad luck to be making a dealer visit so soon. Hope they get it sorted quickly for you mate
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
09-13-2016, 09:58 AM | #3 |
6416
Rep 8,498
Easy. Drive round the block and back to the dealer after the service manager has assured my he'd cured the suspension knocking.
I've pretty much given up now. It's not getting any worse, and I'm strongly considering changing the top mounts when I change the dampers.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
09-13-2016, 10:35 AM | #4 |
741
Rep 2,511
Car has been kept in for a dashboard removal and wiring check! This disturbs my creak OCD already...
They offered me a 2AT 5 or 7 seat or an X3 so I can fit the pram etc in. Took the X3. Going from a 340i Touring to a 2 Series Active Tourer may have made me suicidal! As an additional key transponder was left in the car, in the arm rest, I wonder if some issue was in play in the factory. The service advisor checked the cars history and there was no mention of item warrantee work, post factory. Hopefully there is nothing beyond a bad connection and they will sort it easily tomorrow... But, if it does persist,what are my options on a 200 mile 12 day old car?
09-13-2016, 10:48 AM | #5 | |
2647
Rep 3,664
Rapidly blinking alarm light can be something as simple as a door, boot or bonnet sensor not registering properly thinking its open. Worth opening all doors, boot and bonnet (and fuel flap for that matter) and then closing them again and re-testing.
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
09-13-2016, 10:56 AM | #6 | |
243
Rep 710
09-13-2016, 10:58 AM | #7 | |
741
Rep 2,511
They did a diagnostic and coding check and decided next step was taking out the centre console for a wiring check... I hope it's nothing sinister. I'm fairly pissed off. The car already has damaged trim, near side windscreen pillar already... So, maybe not the first time it's been it bits?!... Also, gloss plastic looks well swirled after dealer preparation! Only just getting the chance to play with the car and notice things, the boy is finally home and and doing well. So, now I'm not just dashing between work, home and the hospital... So, I'm perspective, the car is just an irritation. But, still worried I've opened up a saga...
Rukka2647.00 |
09-13-2016, 11:00 AM | #8 | |
741
Rep 2,511
09-13-2016, 11:42 AM | #9 | ||
243
Rep 710
HelmutVisor637.00 |
09-13-2016, 11:49 AM | #10 | |
8456
Rep 8,783
Hopefully they will quickly solve the car issue and put it back together properly. Maybe worth getting the damaged trim replaced at the same time? |
Rich9600740.50 |
09-13-2016, 12:12 PM | #11 | |
741
Rep 2,511
MashinBenzin8456.00 |
09-13-2016, 01:03 PM | #12 |
83
Rep 173
Rich in the first 4 weeks you can refuse the car and get your money back. Next cut off point is 6 months, reading the legislation I'm not entirely clear as to where I stand but it says you can come to an agreement with the manufacturer to buy the car back or replace it. After that you are stuck with it.
Mine was scratched in several places on collection day (individual paint) and I swear has the loudest creaking seal problem of any car on earth. I have several niggly electrical faults which are really pissing me off and every week or two something else happens. I'm just outside the six month window but it's spent lots of time in the garage and I wait three weeks each time to book it back in. Pretty close to getting rid of it. If you aren't 100% happy in the first 4 weeks... |
Rich9600740.50 |
09-13-2016, 01:29 PM | #13 | |
1983
Rep 3,216
After that first 4 weeks, until 6 months, you have the right to reject, but the garage is allowed to have ONE attempt to fix first (again, you can choose to allow further attempts, but your choice always), and they can make a 'reasonable deduction' from the refund for the use you have had of the car. Exactly what that figure would be will only be determined by the courts in due time, once a number of cases have been through dispute. So it's quite simple if you're still within the first 4 weeks. Inform them that you intend invoking your CRA rights, and watch the panic hit. I guarantee you'll be first in the queue, and your car will get their best technician on it. |
Rich9600740.50 |
09-13-2016, 02:30 PM | #14 | |
741
Rep 2,511
I have a good relationship with the dealer and I expect them to do what's required... However, should I have no joy in the next week or so I can at least mutter about rejecting the car. Though, I hope it's fixed and still creak free for me tomorrow.
09-13-2016, 02:46 PM | #15 |
119
Rep 280
Less than 10 miles after collecting my brand new M135i it announced:
LOW ENGINE OIL PRESSURE - STOP DRIVING IMMEDIATELY! (or words to that effect) Fortunately I was only round the corner from the dealer so I trundled it back in and had to wait while they checked the car over. Thankfully there was nothing wrong and it never did it again, but not the best new car pickup ever!
Current thing: Mk7.5 Golf GTI Performance Isaac Blue
Old thing: F31 340i M Sport Silver/Red |
09-13-2016, 02:47 PM | #16 |
6659
Rep 15,858
09-13-2016, 02:48 PM | #17 |
119
Rep 280
Oh, and when I collected the 330d I had the horror of finding it plastered will all the M badges and model designation, even though I had ordered it fully de-badged.
09-13-2016, 03:00 PM | #18 |
Fool
1857
Rep 3,542
First 330D lasted about 10 miles before I turned around and got them to remove the shipping blocks...
HelmutVisor637.00 |
09-13-2016, 03:29 PM | #19 |
773
Rep 1,643
Drives: 2020 Audi SQ7 & 2019 AM DB11
Location: The Democratic Peoples Republic Of South East England
Wifes dad had a Vauxhall zafira that caugh fire so received a hire car from thrifty which was a brand new mondeo with under 20mls on the clock.
He drove 2 miles down the road and the timing belt snapped. To cap if off when He eventually got home the cat had died What a day |
HeresMyCar258.00 |
09-13-2016, 04:13 PM | #20 | ||
2647
Rep 3,664
Try not to let it detract from a really good car. I'm sure they'll sort it.
Current: M4 G82
09-13-2016, 04:21 PM | #21 |
258
Rep 3,815
warranty
I think under 1000 miles when my bonnett switch failed resulting in false bonnett open warnings.
Days before xmas
F30 335i M Sport - now departed
