How to raise boost Limit on Procede REV3
09-12-2016, 03:04 PM | #1 |
Rep 38
I know this is not nearly as supported as JB4 but I basically use mine for emissions testing with the o2 modifier and meth control. I would like to know if anyone knows of a solution for getting past the 20psi boost limit in the software. If not I will probably just get an external controller for my meth injection .
09-12-2016, 06:03 PM | #3 |
Rep 38
09-13-2016, 08:11 PM | #4 |
76
Rep 911
There is in the software a menu on the left side. Here you can adjust inputs. You need to set the right voltage mapping. Search on google for some example and how to translate the sensor output towards the input settings of the input. You eed to provide a range.
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
