09-12-2016, 01:27 PM | #1 |
310
Rep 1,338
Drives: 2014 F30 320D X-Drive
F30 Factory Folding Mirrors & Cruise Control Quick Question
i have no problems with the mirrors but was wondering if anyone knows how to get the mirrors to fold automatically when i lock the car without keep pressing the lock button continuously, anyone?
My wife's ford fiesta works that as you lock the car with a single press both mirrors just fold in. Last edited by vadimo; 09-13-2016 at 12:10 PM.. |
09-12-2016, 01:38 PM | #3 |
310
Rep 1,338
new here, had F30 since Saturday, whats this 'code' - whats involved? I got to be careful as my car has got warranty and do not want to void.
I also glanced somewhere you can code adaptive cruise control (where it brakes in front of other cars)? |
09-12-2016, 01:56 PM | #4 |
57
Rep 168
I haven't coded before so can't help with that one but you will need a special cable and software. There are plenty threads on it and some information on how to code. Quite detailed of you have a search. I can't search at the moment as I'm on the app.
Regarding the adaptive, I'm sure you'll need to have the radar as a starting point. Do you have that little black box on the front lower grill? |
09-12-2016, 02:58 PM | #5 | |
2647
Rep 3,664
Folding mirrors on lock - yes, you can code that. There is a whole section on these forums on how to code and what you can change - do a quick search and you should find it
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
09-12-2016, 04:54 PM | #7 |
310
Rep 1,338
yes but my car has cruise control module present so as the front parking sensors that ACC uses to measure distance? hardware is there.
09-12-2016, 04:59 PM | #8 | |
131
Rep 395
09-12-2016, 05:01 PM | #9 | ||
741
Rep 2,511
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
09-12-2016, 05:02 PM | #10 | |
637
Rep 817
Umm, I'm no techy type but the range of the parking sensors may not have the range to prevent you smashing in to a car in front regardless of what wizardy they are plugged in to for ACC. As has been mentioned, ACC utilises its own radar sensor. No1 in the diagram. |
09-12-2016, 05:05 PM | #11 | |||
131
Rep 395
09-12-2016, 05:07 PM | #12 |
637
Rep 817
09-12-2016, 05:13 PM | #13 |
131
Rep 395
Haha! I'm making the same point you make in that by the time the parking sensors notice a car in front, it's probably too late to do anything. It's amusing actually that someone could think they are all that's needed
09-12-2016, 05:29 PM | #15 | |
189
Rep 527
The latter requires a separate radar sensor. Check out my signature pic. ACC radar is the little square in the lower grille. New Golfs seem to have them as standard, as each one I seem to see has one.
Current = 2019 G32 630i M Sport+
Previous = 2016 F31 330d Touring M Sport+ & MPPK Last edited by GaryUFM; 09-12-2016 at 05:40 PM.. |
09-12-2016, 05:32 PM | #16 | |
636
Rep 968
Active Cruise Control is 5DF Active Cruise Ctrl+stop&go Funct. |
Rukka2647.00 |
09-12-2016, 05:32 PM | #17 | |
741
Rep 2,511
I think it is standard on all F3X cars. Even my wife Mini has this.
09-12-2016, 05:32 PM | #18 | |
637
Rep 817
544 is normal cruise control. If you wind the speed down with cruise engaged (via steering wheel control), there comes a point where the speed difference from your current speed to the one you have selected applies the brakes. Active Cruise utilises a radar control unit in the nose that keeps your car a predetermined distance from the one ahead. If it slows down, you do too. |
09-13-2016, 01:05 AM | #19 | ||
2647
Rep 3,664
The standard cruise control (with brake function) will only brake when going down hill to maintain the set speed. It's actually CBC (cornering brake control) that steps in if you look like overcooking a corner. It measures speed and steering angle to estimate if you will make the radius. Active Cruise Control "paces" the car in front and will slow you to a stop (within limits) if the car in front slows/stops. To fit ACC you would need the Radar, the steering wheel buttons to set it and probably a whole shopping list of other hardware in between. You cannot simply code it.
Current: M4 G82
09-13-2016, 01:53 AM | #20 |
146
Rep 305
DarrenL_007208.50 |
09-13-2016, 04:22 AM | #22 |
3719
Rep 8,636
Lol at this thread.
Cruise with brake simply brakes to keep you at the speed you set. Active cruise uses radar to maintain the distance behind the car in front, and no it does not use parking sensors lmfao! There is a rectangular radar assembly in the lower grill. So no you ain't in any way shape or form going to simply code it |
mpawood130.50 |
