Not enough traction with JB4
09-10-2016, 12:07 AM | #1 |
62
Rep 460
In 1st / 2nd gear I get a lot of wheel spin. I'm using Michelin PSS, map 5 JB4 (about 14 psi boost). What do you recommend limiting the boost to? What else can I do to gain traction (as I'm not running anywhere close to the whp that others on this forum run)?
Thanks!
2008 E90 335i: JB4 G5 ISO | BMS Pump Gas Backend Flash | ER Charge Pipe | n54Tuning DPs | ETS FMIC
09-10-2016, 12:52 AM | #3 |
52
Rep 278
What temps? I hook pretty good on MPSS. Stock run flats, different story. I'm DCT though.
Eduardo_saanchez0.00 |
09-10-2016, 03:18 AM | #4 |
827
Rep 3,189
There must be something wrong in the rear to lose traction especially with good tyres.
Check your tyre pressure if its up near 40 maybe drop it to 36 or 34. Have you got LSD? You shouldnt have to worry about losing grip till you have upgraded turbos and inlets on e85 mixes |
09-10-2016, 09:54 AM | #5 |
LongDongSilver
274
Rep 706
uhh... get a new tire and wheel setup? lol you're making much more power than stock now, you're gonna need much more tire
N54 E90 6AT: 3" Pipes that go down, Thing that cools the inter, PE Mod, DCI, ST XTA, Whiteline bushings, Aodhan, and lotsa corn-juice
09-10-2016, 10:26 AM | #7 | |
93
Rep 605
09-10-2016, 05:37 PM | #11 | |
bOrN To DiE
413
Rep 1,738
09-11-2016, 11:46 AM | #14 | |
62
Rep 460
I don't have LSD. Is that something you have?
09-11-2016, 01:09 PM | #15 |
146
Rep 1,201
What size tires? MPSS isn't that great for straight-line grip, especially if you peg-leg
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
09-11-2016, 03:27 PM | #17 |
bOrN To DiE
413
Rep 1,738
09-11-2016, 03:53 PM | #18 |
654
Rep 946
09-11-2016, 03:58 PM | #19 |
bOrN To DiE
413
Rep 1,738
09-11-2016, 10:57 PM | #20 |
2032
Rep 8,339
Pressures are high. Should be 32-33ish. Back that hard lowers traction. The pressures should be what's on your door sill regardless of switching sizes or types of tires.
09-11-2016, 11:03 PM | #21 |
bOrN To DiE
413
Rep 1,738
09-11-2016, 11:06 PM | #22 |
bOrN To DiE
413
Rep 1,738
By the way I had a chance to ride my friends 1000HP supra and I told him try to spin the tires at 70+mph he looked at me and said huh?
