30BE - Injector Calibration, plausibility
09-07-2016, 11:44 PM | #1 |
13
Rep 22
Drives: 2007 335i Coupe
I've been getting this code for a little while now and I'm not really sure where to start (other than probably the injectors?)
Some symptoms I have been getting recently is when I cold start the car it stumbles then starts instead up the usual "VROOM" up to 1300ish RPMs. Sometimes I'll get what feels like a bad misfire as well which leads me to believe there's something up with the injectors. I've read the DIY on coding injectors and it seems pretty simple however as far as I know the injectors have never been replaced? Should I pull them out and just jot down the numbers to verify myself they are coded correctly or just replace them? And even then I'm assuming I'd have to replace them all because this code is not telling me which injector the problem is in.. :/ A plus side of replacing all injectors though would be no more tick I guess |
09-08-2016, 05:31 AM | #2 |
327
Rep 960
no need to remove them. just take the engine cover off and the numbers are clearly visible. if you've got inpa it'll show the existing coded values if they dont line up then there is your issue if they do then coding isn't the problem.
Probably take you 20-30mins all up to check and verify coding as well as clean up. |
feuer4275.50 |
09-22-2016, 05:42 PM | #4 | |
13
Rep 22
09-23-2016, 01:37 AM | #5 |
530
Rep 2,083
Check the coding in INPA. If it's all correct then you might have a bad/leaking injector. You can pull them out one by one and see if the tip is excessively black and sooty.
07-20-2017, 05:56 PM | #6 |
42
Rep 367
hate to bring up an old thread, but this is happening to me right now. only difference is i just replaced all six of my injectors prior to getting this code. it ran fine for a few days and then the codes started coming in. I am going to double check inpa to make sure i didn't make a typo, but i think it is good. Although i do remember a few of them getting a red exclamation point in inpa when i typed them in. Any ideas?
Vrsf fmic, vrsf charge pipe with bov, vrsf catless down pipes, afe intake, manzo exhaust, bms jb4, bms cowl filters, bms oil cooler valve, 19" Konig Oversteer wheels, wrapped up, hood vents, carbon fiber wing, custom headlights, air lift v2 airbag system
12-01-2017, 01:54 AM | #9 | |
90
Rep 110
12-01-2017, 03:36 AM | #10 |
264
Rep 459
I'm guessing some other people got bad injectors like you did. I'm wondering if this "refurbishing" process involves removing the numbers off a used index 9 injector and printing index 12 on it along with some randomized calibration digits. Do your injectors have a 2 letter code dot-engraved in the metal just above the index number. Real index 12s have a BO or BD engraved on them signifying internal improvements.
Chris@VargasTurboTech1933.00 |
09-21-2021, 07:30 AM | #12 |
528
Rep 1,165
Drives: 09 E92 335i 6MT
Last update to this thread was 2017.
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
