Missfire on Cylinder 4 almost only at idle?
09-07-2016, 06:50 PM | #1 |
15
Rep 81
OK ive been having an issue with my engine running improperly since getting my car at first it never threw any codes and just ran rather rough (Many people said these cars tend to run a bit rough so I ignored it). Well I eventually got a code for the missfire on cylinder 4 and have since been trying to fix the issue. So I've checked rough running in INPA and it is running in the red (Not sure what metric is used for the rough running category) while all other cylinders run between 1.9 - 0.9 on average cylinder number 4 peaks at 4-5 and averages around a 3. But this mostly happens at idle. When I am driving the car Cylinder 4 still goes a little bit into the read but for the most part it behaves normally. Also to note my idle can get super low (On the way home it was running around 525RPM-575RPM). So far I've cleaned the intake valves, replaced the spark plug and switched the coilpack of cylinder 4 with cylinder 2 to confirm it was not the coilpack. The next obvious step is to replace the injector. Just wanted to see if anyone else had any insight as to why it mainly happens at idle and if the injector is really where the problem is as I am starting to tire of throwing money at a problem with no results any would greatly be appreciated!
09-07-2016, 08:38 PM | #4 |
15
Rep 81
Good to know, thanks for sharing! I must say it was so frustrating to pull the plug today and see a perfectly good plug lol! Same thing when It continued after cleaning the intake valves lol. Hopefully the new injector will put this damn issue to bed!
09-07-2016, 08:42 PM | #5 |
15
Rep 81
09-07-2016, 10:28 PM | #6 |
654
Rep 946
Just for future reference: plugs and coil problems tend to show up under high boost, high RPM conditions. Fuel injectors tend to show up during cold starts and while idling.
09-09-2016, 07:35 AM | #7 |
15
Rep 81
Yah no issues with starting just idling but I guess if it's one cylinder that isn't even fully malfunctioning I probably wouldn't have to many issues there.
09-09-2016, 12:42 PM | #8 |
Ballin' out of control.
520
Rep 1,289
I would take a look at the cylinder-selective injector adaptation readings in INPA...MSD80 -> F5 -> Shift-F6 -> F1
Per the engine management training module (page 36): http://www.e90post.com/forums/attach...8&d=1165592709 Adaptation of the injector opening signal is based on smooth running monitoring of the engine. My guess is that the injection time (einspritzzeit) for cylinder 4 will be skewed when compared to the rest.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
TrollToll654.00 |
09-16-2016, 10:14 AM | #9 |
Rep 28
Had this issue... Replaced the Coils and Plugs... it went away for a little while and then came back.. replaced the injectors and the issue has been resolved. I was getting misfires on 5 and 6.
09-16-2016, 02:07 PM | #10 |
Rep 4
Swap the parts between cylinders to see if the problem follows. If it doesn't, it could be an intake manifold gasket blown on that cylinder (that was fun to track down on one of my older cars).
09-19-2016, 11:42 AM | #12 |
15
Rep 81
Update: Replaced the injector last night and she's running like a well oiled machine! Thanks for the Help everyone and sorry I didn't see the later replies until now. Thanks again guys!
09-19-2016, 12:50 PM | #13 | |
197
Rep 1,070
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
