09-03-2016, 02:59 PM | #1 |
286
Rep 506
Engine sound below 1500-2000 rpm
Has anyone noticed that the engine slightly more diesel like below 1500-2000??? After this on the motorway it seems to sound a lot quieter...
Incoming BG X3 M40i
09-03-2016, 06:29 PM | #2 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
That's how they are. Off boost at around 1500 rpm they sound quite rattly. I sold on my 330d for a 335i because of it. Many don't notice or don't consider it a problem, but some - like me - do.
sahajesh2294.00 |
09-03-2016, 06:35 PM | #3 |
153
Rep 449
It's just an unfortunate feature. Low revs, slowly going up an incline and it does sound rough and nasty. I suppose you just can't get rid of that old tractor rattle from these oil burners.
09-04-2016, 12:55 AM | #5 |
6414
Rep 8,498
30D ? I can't see from the App.
If so, it's a common issue. 1500-1800 under light load produces a noticeable tapping sound, a bit like knock (pinking) on a petrol unit with ignition too advanced.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
09-04-2016, 01:56 AM | #6 |
73
Rep 298
Without going into a big debate about fuels, Ive always found the using BP ultimate diesel helps reduce this clatter. Engine runs noticeably quieter and smoother - I too don't like the rattle and hats one of the reasons I pay a bit extra for premium fuel.
M340i Touring - Tanzanite, sunroof, tech pack, visibility pack, comfort pack…
Z4 Coupe 3.0si - Stratus Grey, ST XTAs, Eisenmann, PSD Short Shift, Xenons, New England Leather |
09-04-2016, 03:10 AM | #8 | |
3122
Rep 5,681
ETA: I've used both Shell V-Power and BP Ultimate and no discernible difference over standard Shell/BP with either IMO. |
09-04-2016, 03:31 AM | #9 | |
Barge driver
8656
Rep 12,425
I tried the different fuels as well no discernable difference, it's just what they do.
730d/Z4C
09-04-2016, 04:26 AM | #11 | |
6414
Rep 8,498
Just as long as it's not supermarket special, which makes the engine sound like it's running on gravel.
09-04-2016, 08:15 AM | #12 | |
483
Rep 1,189
I am finding it amusing that 6 pot owners are complaining about noise and rough running!!. the auto gearbox on the 320d tends to keep the revs above 1500 even on light throttle. Is that rev habit lower on the 330D with its higher gearing or are individuals hitting lower revs due to manual control? Last edited by pmgreenwood; 09-04-2016 at 08:41 AM.. |
09-04-2016, 08:33 AM | #13 | |
6414
Rep 8,498
09-04-2016, 08:43 AM | #14 |
483
Rep 1,189
09-04-2016, 08:51 AM | #15 | |
6659
Rep 15,858
Seems from what I'm reading, it is more an issue with N57 engines, (we've run M57 variants, 30d & 35d, no such problem on light loads across the rpm). Whether this is part of the strategy to get better NEDC results and/or Euro 6 compliance, I'm not sure, but does appear it could be to do with the multi-phase injection for the sound track described. Most older designs of diesel would do this, easy to replicate on and off a light throttle. I'm suspicious its to do with the rev range and loads most used in the NEDC test. Tuned to use less fuel in that critical range. 320d ED I drove had very loud diesel combustion on light loads. Again hints at injection strategy for good headline mpg and CO2 figures. |
09-04-2016, 08:56 AM | #16 |
6414
Rep 8,498
There are several ways to eradicate the noise : stick left, one or two presses on the Sport button, depress throttle. All very effective in my experience
09-04-2016, 09:29 AM | #17 | |
2647
Rep 3,664
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
09-04-2016, 12:13 PM | #18 | |
512
Rep 1,404
Current - F80 M3 CP SS/SO | M Performance Extras
Prev - F30 330D M Sport | White | M Performance Kit | Various Extras Prev - E92 330D M Sport | Black | Highline Older - E46 330i | Silver | AC Schnitzer, E36 328i Coupe | White |
09-04-2016, 01:26 PM | #20 |
Live for today tomorrow never comes
1989
Rep 9,498
Same here sainsbury Diesel is as good as any I have tried, it gives the same MPG, this high octain Diesel is just a money spinner IMO.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
09-04-2016, 01:42 PM | #21 |
2647
Rep 3,664
Mums the word .......
Current: M4 G82
09-04-2016, 01:58 PM | #22 |
106
Rep 155
Yeah but those 40i's are a bit tapperty though aren't they?
Obviously only when the engines cold.... Oh, and at idle speeds mainly.... When stood next to the car outside with the bonnet lifted... Not sure I have got the hang of this consoling lark yet |
Rukka2647.00 |
