Fuel Injector Seal Tools Required?
09-03-2016, 11:46 AM | #1 |
53
Rep 203
I'm buying new fuel injectors without the seals installed. The specialty tools seem very over priced. I'm wondering if I have to buy installation tools or if I can get by without them.
How hard is it to slide the seal on without a tapered cone? Could I use an O-Ring tapered cone or an ear-stud tapered cone instead? Has anybody found a good way to compress the seals without special tools ( hose clamp, zip ties, etc.)? Assenmacher Tools (AST) BMW9054 Fuel Injector and Seal Tool Kit http://www.coastaltoolsupply.com/pro...M-BMW9054.html $106 OEM Fuel Injector Ring Tool 83300495756 https://www.ecstuning.com/b-genuine-...ol/83300495756 $139 OEM SPECIAL TOOLS 83300495761 - no idea what this is https://www.ecstuning.com/Search/Sit...ools/ES256812/ $26
2008 BMW 335xi Coupe 6-speed, 12.8 @ 107
2000 Chevrolet Corvette Z51, 11.4 @ 123 2005 Saturn Ion Redline, 14.1 @ 100 (sold Jun-2013) |
09-04-2016, 10:20 AM | #2 |
193
Rep 666
You absolutely need the tool set. I used Assenmacher Tools (AST) BMW9054 with no issues. Very easy to use.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
09-05-2016, 07:07 AM | #3 |
133
Rep 1,381
I changed all 6 of my N54 Injectors without any special tools.
IMO you don't need them However my injectors came with seals installed (as all OEM BMW part numbered ones should).
09-05-2016, 09:20 AM | #4 |
53
Rep 203
I bought the aftermarket injectors from advanced auto parts that people on this forum recommended
09-05-2016, 09:39 AM | #5 |
40
Rep 91
If you are installing "new" injectors, you don't need any special tools. New injectors should come with new seals that are protected and compressed by a disposable metal sleeve that is removed less than a few minutes before the injector is installed in the head so that the seal does not expand and prevent proper successfull installation into the head.
Just search injector install and you should be fine and be sure to code the injectors when you're done. You need the removal and compression tool when you are swapping injectors as it should increase the probability of a proper installation of new seals (should be new for every installation, people will argue) so that you don't damage the head (leaks) which I imagine is a nightmare. Last edited by OffensiveDriver; 09-05-2016 at 10:58 AM.. |
09-05-2016, 07:00 PM | #6 | |
53
Rep 203
09-05-2016, 11:27 PM | #8 |
40
Rep 91
New injectors have always come with seals but not the decoupling elements. I would say that if the injectors didn't come with seals they may be remanufatured unless I'm missing something. Search.
09-06-2016, 08:01 AM | #9 | ||
53
Rep 203
09-07-2016, 12:56 PM | #10 | |
Rep 52
Have you had any luck with them and did they come with the decoupler rings and seals? Thank you |
09-07-2016, 02:13 PM | #11 | |
53
Rep 203
It says in the info that they don't come with decoulpers or seals. I ordered them elsewhere |
09-07-2016, 03:35 PM | #13 |
53
Rep 203
09-07-2016, 04:19 PM | #14 |
26
Rep 352
i pick it up from bmw this will allow you to put the seal on cost me 50 bucks
it is a cone shape tool you put it on the end of injector then slide seal on. after you slide seal on you have less then 5 min to install |
09-07-2016, 05:12 PM | #15 | |
53
Rep 203
You didn't have to use any of the compressor rings?
2000 Chevrolet Corvette Z51, 11.4 @ 123 2005 Saturn Ion Redline, 14.1 @ 100 (sold Jun-2013) Last edited by tb30570; 09-07-2016 at 05:31 PM.. |
09-11-2016, 07:20 PM | #17 |
53
Rep 203
even though Advanced Autopart's webpage said the OES Genuine injectors didn't come with seals, they actually had seals installed already. The didn't have decoulpers though.
I'm glad I didn't buy any tools.
09-12-2016, 07:26 PM | #18 |
40
Rep 91
03-26-2021, 03:53 PM | #20 |
Rep 15
Want to revive this a bit. I got new injectors from rockauto, they did come with seal pre-installed. However there is no compressive cap on it. I don't know if they stopped doing it or something. Ecstuning told me they even don't include seal with new injectors anymore. I guess my question is do I still need to compress the seal even when it's already "pre-installed"?
03-26-2021, 04:24 PM | #21 | |
528
Rep 1,165
Drives: 09 E92 335i 6MT
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
03-26-2021, 04:40 PM | #22 | |
Rep 15
Also when you say replace the seal did you mean I need to put new one on? I understand the need to compress it but the seal should be new |
