09-01-2016, 04:30 AM | #1 |
2281
Rep 4,933
Stop eco pro display appearing when switching to eco pro.
I do sometimes use eco on a motorway if there is a lot of traffic but it irritates me when you have the nav on it switches to show the extra mpg you are getting on dash display when you press the button.
Can this be coded out does anyone know? cheerz |
09-01-2016, 04:34 AM | #2 |
614
Rep 1,799
You can remove it via display settings in IDrive I think
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
09-01-2016, 07:18 AM | #4 |
792
Rep 2,234
I think he's talking about the extra mpg he's getting in the middle of the cluster, not the display under the rev counter. OP, you simply press the BC button once on the stalk. The same button you can press to toggle between all the different displays between the dials, such as av mpg, av speed, current mpg. You are aware you can do this aren't you? P.S. You can also disable the eco pro display via the iDrive settings. |
09-01-2016, 08:21 AM | #5 |
2281
Rep 4,933
Thanks. I have removed the eco from the idrive settings already but it's where the sat nav info is in the center of the dials that changes to eco rubbish when you switch to eco pro. You then have to use the stalk button as mentioned to get back to the nav directions.
09-01-2016, 08:26 AM | #6 |
922
Rep 2,559
Easy fix. Stop fecking using Eco-Pro!!!
Rukka2647.00 ....,,,,..,,..6732.50 |
