Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Fueling issue after Walbro 255. e85/ stalling
      08-29-2016, 02:38 AM   #1
54VAGE
15
Drives: '09 E92 N54 335i
2009 BMW 335i  [0.00]
So i installed my Walbro 255 today. FBO N54 (no inlets/meth) JB4/mhd and drove the car fine for about 20 minutes, pushing it a little hard but not WOT. decided not to beat on it until the fuel pump gets "broken in". i got into my car after it was parked for about 15 minutes and as soon as i put it in drive it stalls out 10 feet from my parking spot. I try cranking and it turns on, then immediately shuts off. I ran the codes via MHD on the spot.
codes:
2A2D: fuel low pressure system
29DC- cylinder injection switch off
shadow codes:
2FCA- fuel high pressure
2FDA- fuel high pressure.
i only had less than a quarter tank left of my e40 blend. so i got 93 octane and added 6 gallons. Back at half a tank i was hoping the pump gas would help but the car still is stalling out. managed to make it home, will post logs tomorrow if it would be helpful. Any suggestions would be great. for now.. she sits in the driveway
i added logs. any help would be great. thanks
E92 N54
JB4, MHD, Alpina flash, ARM DPs, Cobb CP/HKS bov, BMS DCI/OCV, PE exhaust, 2nd cat delete (vibrant 1792), Mishimoto FMIC, Fuel-It stage 2, Msport
F30 N20 EWG
      08-29-2016, 11:11 AM   #2
wren57
Roll Tide
wren57's Avatar
591
Drives: 335i
Did you install yourself or buy a pre-made bucket? I'm guessing there's an issue with the install. Open her up and triple check everything.
      08-29-2016, 11:41 AM   #3
54VAGE
15
it was installed clean, a forum member came a long way to do it for me. it was just the inline fuel pump we used the same bucket
E92 N54
F30 N20 EWG
      08-29-2016, 08:42 PM   #4
specialist
26
Drives: 335i
pull it out again check lines
      08-29-2016, 11:11 PM   #5
N54Society
Major Private First Class
N54Society's Avatar
449
Drives: 2010 E90 335i M Sport
Sounds like an install issue to me too.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs
      08-30-2016, 11:27 AM   #6
specialist
26
Drives: 335i
It happen to me did you use fuel clips that need a crimp tool or gear clips.
      08-30-2016, 11:35 AM   #7
54VAGE
15
i crimped them. i guess ill have to check the connections again fml
E92 N54
F30 N20 EWG
      08-30-2016, 11:45 AM   #8
wren57
Roll Tide
wren57's Avatar
591
Drives: 335i
If everything is working well, and you change one thing, then things don't work well, pretty obvious that the culprit is going to be something with the change. Hope you're able to solve it easily. GL.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306
Tags
e85, fuel, gas, pump, walbro
