MHD Log + Tired Turbos? :(
08-27-2016, 07:51 PM | #1 |
13
Rep 22
Drives: 2007 335i Coupe
Recently my waste gates have been rattling louder than ever and I removed my JB4 as well as changed from a JB4 back end to a full e40 map with MHD. I included a log below if you guys could give me some insight. I'm on a tight budget as I'm going through a divorce?.
my modifications are as follows: Larger FMIC (Don't remember brand) AFE cold air intake Catless Downpipes Synapse Charge pipe & BOV Car is a 2007 e92 335i with almost 138k miles I'm the second owner. http://www.datazap.me/u/mrg12695/log-1472330619 I'm afraid of how much I'm gonna need to spend, I was looking at VTT stage 1s possibly because I cant simply afford RBs or stage 2s. I talked to B&B Autohaus who I usually take my car to and they quoted 1300-1500 to install new turbos. |
08-27-2016, 07:59 PM | #2 |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
Good chance that the turbos are warn, but the boost solenoids play a big part in closing the WG to allow the turbos to make boost. Recommend replacing the boost solenoids before you go and spend a bunch of money on turbos only to find out the boost solenoids were the primary cause of low boost and rattle.
08-27-2016, 08:02 PM | #3 | |
13
Rep 22
08-28-2016, 12:55 AM | #4 |
198
Rep 562
Hopefully it's something cheap and simple like boost solenoids and/or bad vacuum lines.
On a side note, perhaps someone more knowledgeable can explain why the DME is not applying more wgdc when boost target is clearly not being achieved? Looks like wgdc is only maxing out at 60%. |
08-29-2016, 01:20 PM | #5 | |
13
Rep 22
08-29-2016, 01:46 PM | #6 |
184
Rep 232
you have an injector problem, on bank 2 i think. large discrepancy between bank 1 and 2 fuel trims, and bank 2 is running noticeable leaner than 1. i would address that before anything else, fueling is important. it may be a leaking injector on bank 2, see if your plugs smell of fuel.
in regards to the turbos, while they are definitely not hitting target, wgdc is not overly high. like wedge suggested, swap out the solenoids and see if that fixes the issue. |
08-29-2016, 02:10 PM | #7 | |
13
Rep 22
