FS: iDrive retrofit parts (CCC, CID, Dash, Controller, Etc.)
08-27-2016, 02:07 PM | #1 |
Rep 14
I recently removed iDrive from my 2006 330xi and replaced the "double scoop" dash with a "single scoop" dash. Accordingly, I am offering for sale the hardware that should be needed to retrofit a non-iDrive car, as follows: • CCC / Navigation head unit • iDrive controller • CID – Central Information Display (screen) • Double scoop dashboard (black) • Center speaker grille (for double-scoop dashboard) • Center speaker mounting bracket • Center console trim with iDrive controller hole (brushed aluminum) • Climate control bezel/trim for double-scoop dash • CCC Fan • LVDS Cable You'll obviously need to obtain or build wiring to accommodate the new hardware. You'll also need the cooling hose and various screws (many of which you'll be able to source from your existing dash). I found Booster4075's retrofit DYI to be spot on (even though I was working in reverse). Coding will also be necessary. Everything was in working order when I removed it last weekend. Please let me know if you have any questions. I'm willing to ship at buyer's expense. Asking $400/obo for everything pictured. Thanks for looking, Zach Denver, CO 3zero3-2five0-8seven95 Last edited by zdet; 08-31-2016 at 09:25 PM.. Reason: Added asking price |
09-02-2016, 04:34 PM | #9 |
Rep 14
The following are sold (no longer available):
• CCC / Navigation head unit and bezel • CID – Central Information Display (screen) • CCC Fan All of the following are still available: • iDrive controller • Double scoop dashboard (black) • Center speaker grille (for double-scoop dashboard) • Center speaker mounting bracket • Climate control bezel/trim for double-scoop dash • Center console trim with iDrive controller hole (brushed aluminum) • LVDS Cable Make an offer, I'll probably accept it. |
09-10-2016, 08:42 AM | #11 |
Rep 14
UPDATE:
The following are sold (no longer available): • CCC / Navigation head unit and bezel • CID – Central Information Display (screen) • CCC Fan • Double scoop dashboard (black) • Center speaker grille (for double-scoop dashboard) • Center speaker mounting bracket • Climate control bezel/trim for double-scoop dash All of the following are still available: • iDrive controller • Center console trim with iDrive controller hole (brushed aluminum) • LVDS Cable |
09-16-2016, 09:48 PM | #12 |
Rep 14
Any takers?
Sale prices: • iDrive controller -- $30 • Center console trim with iDrive controller hole (brushed aluminum) -- $25 • LVDS Cable -- Free |
