Stock Airbox with a BMS Drop-in vs an Open Airbox
08-27-2016, 02:26 AM | #1 |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
Have you ever wondered how much power you can I make before upgrading your stock airbox to a MR5 or one of the countless options we have today?
I was actually shocked at the results today... 430.84 vs 416.01 whp Click Here - Datazap.me Almost 15 WHP gained by just removing the top of the stock airbox. Because I didn't have other filters with me to test, I can only conclude two possibilities. 1. The BMS Drop-in Filter is restrictive... Or 2. the cold air snorkel is too restrictive without positive pressure from air flow while driving. The car: Stock '08 Sport E92 AT Stock FMIC, Stock DPs, and 132,000 miles. Mods: Fuel-IT Stage 2 LPFP, ER Charge Pipe with Tial BOV, BMS Drop-In Cloth Filter, and MFactory LSD. Car was walnut blasted within the past 500 miles and has new index 12 injectors. Car was running a high % of E85 today and it was HOT. Was 102 deg F in the shop today. Edit: I want Dimitri ******** to chime in here also as he's done a lot of testing with regard to AFE Cold Air Intake and now ECS Tuning's really cool DCI CF Cold Air Intake box. He might have some supporting numbers also he can throw down. Last edited by WedgePerformance; 08-27-2016 at 06:30 PM.. |
08-27-2016, 03:49 AM | #2 | |
110
Rep 1,340
08-27-2016, 06:03 AM | #3 |
647
Rep 779
If all you did was open the lid and used the same filter, pretty clear it's the snorkel with no incoming air and/or the airbox design itself.
After I added hybrids, I got to wondering if the closed AFE SI single filter/snorkel was too restrictive. I bought DCI and tested the AFE closed (fully sealed), lid off and the DCI back to back. That was on the street with the snorkel functioning (with scoops) and, other than IAT differences between closed and open/DCI by the end of the gear, they were all pretty close on logs and VD. Yours are miles apart by comparison. Why did your IATs suddenly drop 12F before towards the end of the run before you let off? |
08-27-2016, 07:32 AM | #4 |
648
Rep 2,011
If you take the top off, thats unfiltered air going in?
The stock box needs more volume above the filter to be less restrictive.
335i e92 TPC 19Ts
08-27-2016, 08:18 AM | #5 |
654
Rep 946
Bimmer 808170.00 |
08-27-2016, 10:02 AM | #7 |
Liberty or Death
60
Rep 90
Drives: 2007 E92 335i
08-27-2016, 10:09 AM | #9 |
654
Rep 946
08-27-2016, 10:14 AM | #10 |
Head Fry Cook at McBurgertown
507
Rep 1,005
08-27-2016, 10:59 AM | #11 | |
648
Rep 2,011
See the big gaping hole , intake to the turbos. Doesnt matter filter or not.
335i e92 TPC 19Ts
08-27-2016, 01:01 PM | #12 | |
32
Rep 269
I did a similar test with a stock airbox with the bottom cutout for airflow (w/ k&n) and saw significant gains with the DCI setup past 5500 rpm.. |
e92212288.00 |
08-27-2016, 02:32 PM | #13 | |
647
Rep 779
The filter probably isn't helping then, but still leaning towards the snorkel not functioning as being the larger issue since I noticed little difference on my tests with conical filter and open/closed box at speed. Maybe the AFE SI setup is just that much better than stock, but that's with inlets and hybrids at 19psi, so it would have to be significantly better. Quick way for him to find out what's up would be to repeat the tests on a street log and see if that difference is still there (if brave enough to run unfiltered on the street with the snorkel connected). Closed box with filter, closed box no filter, open box tests would tell whether the box or the filter is an issue and how much from each, if any. Edit: I guess the lid wouldn't seal without the filter in place though, would have to cut a filter up or create a separate seal. |
08-27-2016, 02:45 PM | #14 |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
Wait... Running engine straight from atmosphere without any filter is less restrictive? Damn wish I had known
Gonna be a lot of bees getting pulverized in the intake fins of the turbo with that kind of setup on the street.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
Bimmer 808170.00 |
08-27-2016, 05:10 PM | #15 |
654
Rep 946
The benefits are even better in dusty or rainy environments. The abrasive dust particles do a great job of polishing the intake valves and the fine water mist during rain helps cool the turbos.
08-28-2016, 06:48 AM | #16 |
898
Rep 6,285
08-28-2016, 11:57 AM | #17 |
507
Rep 1,005
Back on Topic.
WedgePerformance
Interesting results, particularly considering stock FMIC & DPs. I've seen the previous threads on stock air box/Mr. 5/DCI; however, I'd be extremely interested to see someone replicate similar test with inlets (or inlets & outlets both). It'd be nice to see actual results using current technology. I suspect inlets could make a clean Mr. 5 install (or maybe even Dinan) a more viable performance option. Last edited by terryd5150; 08-28-2016 at 05:30 PM.. |
WedgePerformance1334.00 |
08-28-2016, 09:30 PM | #18 | |
469
Rep 4,392
Removing the cover bypasses all of this, so everyone would think ok time for a DCI. So I decided to seal up an aFe Stage 2 Elite CAI, which is now superseded by the aFe Magnum GT (100% sealed), that has better airflow, and I ran before and after dyno results. I gained 13 whp and 17 wtq more over the factory box with a K&N drop in filter. To make it even more interesting I went back to the dyno with unfavorable weather conditions Stock Turbos like colder air. |
WedgePerformance1334.00 terryd5150507.00 |
08-29-2016, 09:04 PM | #20 | |
32
Rep 269
08-29-2016, 09:25 PM | #21 | ||
110
Rep 1,340
08-29-2016, 09:47 PM | #22 |
32
Rep 269
