08-24-2016, 04:29 PM | #1 |
300
Rep 356
OEM Exhaust Tips Removal
Does anyone know how to remove the chrome OEM exhaust tips without damaging them? It appears they are spot-welded on.
I need to remove them in order to slide the clamp-on C/F tips onto the pipes. |
08-28-2016, 06:27 PM | #2 |
115
Rep 1,439
BUMP
i'm looking for this info too. thanks! |
Swimfanrick51.00 |
08-28-2016, 07:40 PM | #3 |
136
Rep 247
They're just held on by compression springs. So some come off with a good pull while most require knocking off with a soft mallet from the rear. Search for removal guide posted by IND which gave a good how to.
08-29-2016, 04:30 AM | #4 |
263
Rep 337
Drives: '17 M2 DCT BSM
There are adequate tools to do that. A hammer is not one of them.
08-31-2016, 11:22 AM | #6 |
1823
Rep 2,948
A soft rubber mallet is not a hammer
And buying a tip pulling tool for one change is just insanity... hjk What tips did you end up buying? Could you post some pics before installation? I'm thinking of doing the same thing to mine Last edited by gmzanatta; 08-31-2016 at 11:57 AM.. |
mc3456389.50 |
08-31-2016, 11:40 AM | #7 |
BimmerPost Supporting Vendor
23785
Rep 190,128
You should be able to pull them off without any tools, as mentioned above twisting while pulling will make the task easier
BeemerBoost118.00 |
08-31-2016, 11:48 AM | #8 |
1756
Rep 7,651
Agreed, ours came off very easy without much effort.
mike@x-ph.com23785.00 |
10-15-2017, 03:17 PM | #9 |
Rep 3
Mine were put on by Odin himself and then Thor gave them a tap for good measure. I have tried 5 times to get them off, including mallets and pullers...they are still on there. I haven't tried twisting while pulling though, ill give it a shot.
///M TOWN13117.00 |
10-15-2017, 04:22 PM | #10 |
Never underestimate the Home-Bowl
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Twisting while pulling can bend the spring clips, FYI.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
10-15-2017, 09:23 PM | #11 |
345
Rep 340
There is a thread somewhere describing the multiple ways. Most of us did well with a block of wood and rubber mallet. Apply WD40, let sit for 15-30min and whack away. 3-4 good smacks should do it at that point. Don't be bashful when hammering.
10-15-2017, 10:02 PM | #13 |
641
Rep 1,207
I pulled my M2 tips out so I can paint it myself as I felt like the aftermarket options were not to my liking. I had to use a 6" gear puller from harbor freight tools and had to use it with a 12 foot socket wrench handle. I also tried using a piece of wood with a mallet and that did not work too well.
