TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > brake, abs and traction control light on???
      08-24-2016, 03:35 PM   #1
BusaR8
21
Drives: cls 335 busa
So I was doing some pulls and practicing break boosting when all of a sudden I get abs,brakes and traction control lights. I checked codes and there isn't any. Unplugged battery reset codes adaption and I still get the icons. Also AC isn't blowing cold anymore neither has anyone had these issues??
Jpworkz 6466 GEN2 kit single life
      08-24-2016, 06:16 PM   #2
Whinodez
Drives: 2008 335i
Had all these lights on my Land Rover, it was a bad speed wheel sensor
      08-25-2016, 05:07 AM   #3
Prev
Prev's Avatar
Guernsey
Drives: 2009 E92 335i M-Sport 6MT
My 335 is in the local BMW garage as I type having this exact problem fixed. The cause for mine was wheel speed sensor.
2009 - E92 335i with a touch of MHD.
Previous:
2007 - MK1 Mazdaspeed3
1997 - Nissan R33 Skyline GTR V-Spec
2000 - Nissan Patrol LWB
      08-25-2016, 05:21 AM   #4
KJMotorsport
Drives: 135i DCT
Check the codes, if its a sensor swap them round and see if the codes follows. (e.g right hand side rear sensor, swap with left side, clear codes, drive car is the error code changes to left side fault)
AC blowing hot, probably just needs a leak check and a re-gas...
Le Mans Blue/Lemon 10' 135i DCT - N55 - PPK Stage 1, 18" Style 269's w Michelin PS4's
      08-25-2016, 06:30 AM   #5
musa
musa's Avatar
423
Drives: F86, E92, E53, E39.
Did the control lights and AC blowing issue happen at the same time or was the AC issue already preexisting before you went out for your pulls?
      08-25-2016, 06:54 AM   #6
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
How old is your car, how old is your battery? All kinds of weird lights and behaviors happen on these cars when the battery becomes marginal. Mine had all those lights, and things like the radio volume would stop working and it was a voltage issue related to a marginal battery. I replaced mine with an OEM one at 7yrs old.
      08-25-2016, 07:25 AM   #7
Wolf 335
Wolf 335's Avatar
2341
Drives: 2007 E92 335i
Had the exact same issue. The next day I was stranded with a dead alternator.
      08-25-2016, 12:11 PM   #8
BusaR8
21
Right now I am getting these errors
Junction box passenger
Central control timeout
Code 009c5e
Code 009c69
Speed sensor front right
Code 005da0
Right front direction detection
Code 005da6
AC started blowing hot air the same time I got these codes.
      08-25-2016, 12:12 PM   #9
BusaR8
21
2009 e90 335 110,000 miles.
      08-25-2016, 02:12 PM   #10
Wolf 335
Wolf 335's Avatar
2341
Check alternator output voltage
      08-25-2016, 03:34 PM   #11
BusaR8
21
Well guess I believe I figured it out. I did not tuck a wire away and ended up touching the turbine housing lol AC/right sensor wire. Burnt it up thank god I found out easy fix.
      08-25-2016, 03:43 PM   #12
BusaR8
21
Had it tucked under the turner blanket like a Fool!
      08-25-2016, 05:17 PM   #13
musa
musa's Avatar
423
Busa, my car is having the same issue as yours (the dash lights and a/c blowing hot air) in addition to it going into limp mode. This is after doing major repairs on the car, so I suspect I may not have put something together correctly because before the repair all was well. Could you please explain what you mean above? Exactly which parts are you referring to? May be a picture? I think a/c not blowing cold air may hold clue to a fix.
Thanks!
      08-25-2016, 06:13 PM   #14
BusaR8
21
Thanks!
My wires got burnt up it is fixed now no more abs issues or AC blowing hot. The wires that run together on the passenger side ac/front passenger wheel speed sensor. They are in the same wiring harness I'll try and get a picture for you.
      08-25-2016, 09:39 PM   #15
jwebb335xi
197
Drives: 2008 335 XI
Glad you got it fixed!!
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs
