Residue near fuel lines and injector
08-24-2016, 12:22 PM | #1 |
109
Rep 243
Hi all,
A mechanic replaced my injectors for index-12's a couple months ago. Today I removed my engine cover and discovered that on injector 1 and 3 there's a fair bit of residue (fuel?) between the fuel line and the top of the injector. On the second picture, you can see a clear difference between how it should be (left) and how it is on the 3rd injector (right). Are these injectors flawed or is the bolt simply not tight enough / missing a bushing? Thanks in advance! |
08-24-2016, 02:37 PM | #5 |
Guest
Rep n/a
Drives:
Looks like oil to me. Is your oil cap leaking?
I had a little bit of oil on injector 3 too; a bunch of oil had also absorbed into the foam under the engine cover as well. I swapped my original oil cap out for the newest version and no issues since. |
08-24-2016, 03:41 PM | #6 | |
197
Rep 1,070
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
08-24-2016, 03:53 PM | #7 | |
3441
Rep 79,211
OP tighten them up and look at that oil cap area. |
08-24-2016, 03:56 PM | #8 | |
48
Rep 146
Think this might be your problem op. I have an after market oil cap now so maybe that's why mine is'nt 100% sealed.. Wich one do you have fcobra94? |
08-24-2016, 04:10 PM | #9 |
Guest
Rep n/a
Drives:
08-25-2016, 12:09 AM | #10 |
109
Rep 243
Thanks for the replies, Will look into the oil cap. But, how can there be oil on injector 1 when the oil cap is leaking? From what i remember that injector is not near the oil cap.
