electrical tape or heat shrink tubing removal
03-28-2008, 10:01 AM | #1 |
53
Rep 986
do you prefer electical tape or heat shrink tubes for insulating male female connections with the piggybacks?
how easy is it to remove heat shrink tubes without damaging dme wires? |
03-28-2008, 10:07 AM | #2 |
35
Rep 1,169
Drives: 67 GT500,69 Boss 429, 335i
If you want higher quality hold and less junk on the wires use heat shrink. It will take more time to remove but will look better and be more reliable in my opinion. The way i know how to remove it is with a exacto. You could probably also reheat it to make it pliable.
-Mat
Tuned E92 335, Riss Racing downpipes! And hopefully over 400RWHP!! |
03-28-2008, 10:44 AM | #3 |
40
Rep 494
I would def go with the heat shrink...much cleaner and professional looking. this also helps wires blend in with the rest of the factory wiring which is a plus just in case anyone wanted to take a quick look-see at the ECU area. with electrical tape anyone will tell immediately that you have tampered with the wiring.
I went with heat shrink for my JB2H connections and once I tucked the JB well in the ECU box the heat shrink blends all connections nicely. As for removing it if I have to I will just carefully use a small blade i.e. exacto or razor to gently cut around the heat shrink....you could use some medical scissors with the edged tip that can help cut without damaging the wires beneath. good luck! |
03-28-2008, 11:06 AM | #5 |
53
Rep 986
thanks for the helpful tips. I've never used heat shrink tubes. How do you use them? The install guide recommends cigarette lighter. do you heat up the entire tube and for how long?
Just want my AA install to go smooth. |
03-28-2008, 11:22 AM | #6 |
11
Rep 677
Im always using a lighter. you will see it. heat it up til it fits nicely. it takes just a few seconds.
59 Corvette, 72 240Z, 73 Espada, ZXR
03-28-2008, 12:04 PM | #8 |
16
Rep 372
Do the shrink, I did it last night with my Processor and the looks of the install are top notch, a big plus! You'll be very satisfied.
Georgie Vazquez Mayaguez, PR R.I.P. 335i, 010 135i here! |
03-28-2008, 01:03 PM | #9 |
19
Rep 358
2007 E92 335i - Alpine White, Coral, 6 Speed MT, Premium, Sport, Painted Reflectors, GT thunder Angel Eyes, M-Tec Fogs, Cyba CF Kidney Grills, Black OEM Lower Mesh, OEM Aero-Lip, 19" Staggered Matte Black VMR CSL Reps, General Exclaims - 235 Front and 265 Rear, Black Window Trim, BMS Dual Filter Intake, Britalman Catback Exhaust, CF Mirrors, CF M3 trunk lip, 5% Tint, Lamin-X Tinted Tails, Split Second Turbo Tuner.
03-28-2008, 04:05 PM | #11 |
274
Rep 6,510
03-28-2008, 06:49 PM | #12 | |
Rep 386
Since masking tape contains paper, isn't it more flamable? That's just asking for trouble.
2011.5 M3 Coupe: Space Gray, 4MY, ZCP, ZCV, ZP2, 494, 5AC, 655, and 752
Mods: Full Venture Shield protection kit, RPi scoops, Euro fog light switch, LUX V4, clear reflectors, OEM black chrome grilles and side gills, black hood vents, IND F10 M5 shift knob and boot |
03-28-2008, 06:52 PM | #13 | |
310
Rep 15,745
thats like the biggest load of shit Ive ever heard. No traces of install? Cut wires or splices wont give it away..but residue from electrical tape will, so better use masking tape!!!! Not to mention the second it gets cold out, it will just lose stick...not covering your wire job, possibly arcing to something if it touches metal.. |
03-28-2008, 07:04 PM | #15 | ||
274
Rep 6,510
I'll let you know if my ECU bursts into flames from the horrible deadly masking monster... Who is cutting wires?!!?!?!?!? there is no cutting or splicing... |
03-28-2008, 07:10 PM | #16 |
48
Rep 1,664
Or, take your time with electrical tape.... the technique is sound, some people will just make a mess out of anything.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
03-29-2008, 09:03 AM | #17 |
grand poobah
254
Rep 2,253
The electrical tape will leave that lovely black glue residue. It easily removed with some electrical contact cleaner though.
Heat shrink is good you just need to be careful of a few things. Do not get the kind that has the glue built into the inside of the tubing and be careful when heating it to not burn the insulation outside the heat shrink or get the heat shrink hot enough that it sticks to what you are working on. This depends mostly on what you are using to heat it. A heat gun is the safest way to go. Also when removing it you have to be careful not to damage any connectors when pulling it apart or not to cut insulation if you use a razor blade. I would not recommend masking tape for this project. After a while living with the heat in the engine bay it may not work to well. |
03-29-2008, 09:37 AM | #18 |
58
Rep 1,230
If your piggyback is a long term install unlike some who are continually removing them for changes and upgrades, I would definitely consider heat shrinking your pin connections. Another alternative I'm considering is a product I use called "Self Amalgamating Rubber Tape" which has no glue as such, but is tightly stretched and wound several times over the conductive pins. It's advantage is, it can be unwound any time in the future, it provides a waterproof connection and it doesn't deteriorate or leave gooey residue behind.
Masking tape should be considered a temporary measure alone as it is prone to coming apart and exposing the conductive pins due to the glue residue composition changing with age and heat fluctuations within the confines of the engine bay. You have been warned................and yes I'm an electrician and have seen the long term affects of using masking tape and its eventual lack of sticking power. .
Sticky is an Idiot
03-29-2008, 09:40 AM | #19 | |
310
Rep 15,745
I just loovvee working on cars like yours that come in with masking tape around connections...I have seen it quite a few times |
03-29-2008, 11:24 AM | #20 | |
137
Rep 6,608
2. Masking tape is not going to catch of fire in the ECU 3. Masking tape it the easiest thing to use because it leaves absolutally no residue... 4. for thinking you know so damn much....
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote. |
03-29-2008, 12:12 PM | #21 |
Modder Raider
758
Rep 8,633
Drives: M3
Masking tape really is a good thing to use.
Remember that we aren't talking about huge amounts of current here, so I truly wouln't worry about your ecu going up in flames. The amount of votage that is going through the wires is so small. The con about masking tape is that after time it will be a little harder to take off if you need to. When you peal off the tape then it will come off in slivers and it might take more than a couple tries to get the all of the tape off of a single connection. If you want to use electrical tape then it will leave a bunch of residue but I just used goo gone or (goof off) to take care of this residue. The goo gone works like a charm. The best connection is the heat shrink only if you plan on leaving the tuner on for a long time, but if you're me and you swap tuners every couple weeks then the heat shrink is definitely not an option.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
03-29-2008, 12:18 PM | #22 | |
274
Rep 6,510
its so you can TAKE IT OFF! Sorry, but that was just way too obvious Anyone that goes to the dealer with tape on their ECU connections is asking for trouble... hence the reason to use a tape that comes off easily and doesnt leave residue... |
