08-22-2016, 02:47 PM | #1 |
416
Rep 941
Tracking and alignment - expensive??
So after a year of driving on the UK's less than perfect roads and my tracking was slightly out on my F31. Not a problem, I'll get it done next time it's in for a warranty item I thought...
I dropped it off and noticed the price was down for £180 on the service sheet... Now, it's been a few years since I had to pay for it but it was never that much - £80 at the most!!! Are they having my trousers down or does £180 seem reasonable to you?
Individual SY F80 / insta:@dubdemand
08-22-2016, 02:56 PM | #2 |
6414
Rep 8,498
If that price is just for tracking then it's very expensive. If it's a full 4 wheel laser alignment then it's not too bad. I paid about £160 at a local specialist for a 4 wheel Hunter alignment around a year ago.
EDIT - memory check, it was around £110.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
08-22-2016, 03:21 PM | #3 |
416
Rep 941
Fair play, I think it is lazer alignment so maybe it's not that bad then. Hopefully the car will feel better as a result!
08-22-2016, 03:48 PM | #4 |
2876
Rep 3,966
I used Black Boots/Wheels-In Motion based on forum recommendations. Paid around £80 from memory. Very competent.
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
08-22-2016, 05:41 PM | #5 |
58
Rep 2,398
not much help to you i know, but i drop mine in to my local tyre shop that also happens to have a hunter system, and they charge me about £35 once a year to check it, and tweak it if required.
If the "before" print-out shows all green, then it's free! Little and often, little and often
Now: F20 M140i
Prev: F21 118d, E92 325d |
08-23-2016, 01:59 AM | #9 | |
6414
Rep 8,498
08-23-2016, 05:28 AM | #11 |
10995
Rep 32,881
If it's just that you steering wheel isn't straight then it's pretty easy to adjust the front toe yourself, I did a guide here:
Adjusting front steering toe yourself http://f30.bimmerpost.com/forums/sho....php?t=1177440 Coopers couldn't actually get the steering wheel straight (long story ) so I ended up doing it myself! |
08-23-2016, 05:55 AM | #12 |
3122
Rep 5,681
Had laser alignment checks and adjustment done on a couple of my cars including the F31 when I changed all the tyres in January this year; from memory the cost was around £75 so £180 sounds a tad on the high side.....
08-23-2016, 07:06 AM | #13 |
130
Rep 358
The previous car,Lexus IS250,wandered all over the place until I had the alignments sorted.
It was done at the local Ford dealer,on a Hunter machine,and I was amazed at the price...a touch over £30!! I would also add that the tyres had worn unevenly and it was not until these were replaced that the car felt 100% right. |
08-23-2016, 08:08 AM | #14 |
121
Rep 419
That seems quite a lot, and I'd want to see a full print out of before and after to see what they did. And its a bit like going to a GP for a specialist operation.
A couple of years ago Tony at Wheels in Motion did a full 'Fast Road' set up on my MX5 and that was about £100. The car was transformed. |
08-31-2016, 04:05 AM | #16 |
3719
Rep 8,636
http://www.merrow-tyres.co.uk/
Based in Farnham have a very good rep and I've used them a few times. They were a lot less than £180! |
08-31-2016, 04:15 AM | #17 | |
849
Rep 1,858
08-31-2016, 09:21 AM | #18 |
288
Rep 1,201
I paid £130 for hunter alignment in manchester about a month ago. the car was only slightly out so I felt a bit overcharged but hey at least it's spot on now. well worth it if your running expensive tyres
