TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > VRSF 1000whp 7.5" Race FMIC Pre-order Now Available!
      08-21-2016, 08:07 PM   #1
Tiago@VRSF
Tiago@VRSF's Avatar
2095
Drives: F90 M5
We finally finished up production on our race intercooler and after extensive testing on some incredibly fast cars we're finally ready to offer a pre-order for our new 7.5" stepped race intercooler.
The new ultra high density intercooler is 134% larger than the OEM intercooler @ a total of 1080 cubic inches & it's rated for over 1000whp. This is the best solution for any customer running upgraded turbos who is looking for an incredibly efficient intercooler at a reasonable cost without sacrificing quality.
We're expecting these to arrive in stock within the next 4 weeks and will be offering introductory pricing directly on our website.
Results:
We've had a few beta testers in the 650whp+ report fantastic results with 3rd gear pulls (22-30 psi) averaging a 0-1 degree rise, 4th gear pulls in the same boost range are 3-4 degrees. 2-4 gear pulls are showing no IAT increase from 2nd through 3rd with a 7 degree overall rise into 4th.
Below is an example of a car running more boost (35 psi) at a much higher HP level (790whp) showing a rise of 11 degree rise in 4th gear. This car also noticed a significantly lower overall pressure drop due to the increased flow of the much larger core.
Eye Candy:
Appreciate 3
      08-22-2016, 04:50 AM   #2
JTswole83
34
Drives: 335i
Damn that is great! I was starting pulls in the 90* range from a 60-150 pull and would end up around 180* IAT!
      08-22-2016, 08:04 AM   #3
2jzn54
41
Drives: 07 E90 335i 6MT
What readily available plumbing are you using on the connections?
      08-22-2016, 10:21 AM   #4
Tiago@VRSF
Tiago@VRSF's Avatar
2095
Drives: F90 M5
The same plumbing used on our existing 7" FMIC. These will fit any chargepipe without the need to modify your existing chargepipe like the other larger solutions
      08-22-2016, 11:07 AM   #5
Bimmer 808
MT or bust!
170
Drives: 2010 E90 335i M Sport, 6MT
2020 X3 M40i  [0.00]
2015 M235i  [0.00]
2006 330i  [0.00]
2010 335i  [0.00]
Definitely interested. I currently have your 7in. Do you have installation notes for DIY? Bumper removal needed if I have a lift available?
Thanks
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
      08-22-2016, 12:45 PM   #6
Tiago@VRSF
Tiago@VRSF's Avatar
2095
Drives: F90 M5
The bumper definitely has to come off. The DIY is the same as the 7" unit, it just requires a bit more trimming up top.
      08-22-2016, 12:56 PM   #7
3000GT MR
3000GT MR's Avatar
265
Drives: 09 335i/3000gt vr4
Looking good Tiago!
Does this have a 3 or 3.5" outlet?
I'll be picking one of these up.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust
335i 2009 e90 665RWHP VFF900 ST RIP .
      08-22-2016, 01:00 PM   #8
Tiago@VRSF
Tiago@VRSF's Avatar
2095
Drives: F90 M5
2.75" ID/3" OD inlet/outlet.
We're going to offer a larger lower chargepipe with the race models and we're also going to offer a larger lower chargepipe upgrade for the original 7" kits.
      08-22-2016, 01:58 PM   #9
2jzn54
41
good stuff tiago
      08-22-2016, 02:24 PM   #10
LQQKOUT
102
Drives: 335XI
Is the larger lower charge pipe going to be available at the same time the 7.5" will get released.
      08-22-2016, 02:24 PM   #11
Tiago@VRSF
Tiago@VRSF's Avatar
2095
Drives: F90 M5
Yes sir!
      08-22-2016, 06:40 PM   #12
mike@x-ph.com
BimmerPost Supporting Vendor
mike@x-ph.com's Avatar
24198
Drives: 07-335/12-328/18-M4/21-M4CP
Looks great!
https://x-ph.com/sale/
Phone number 702-494-9435
      08-22-2016, 10:32 PM   #13
E90gone
20
Drives: E90
Still no anodizing?
      08-22-2016, 10:42 PM   #14
Sered
Sered's Avatar
146
Drives: 08 E90 335i
Is the lower charge pipe upgrade for the original 7" kits available on the pre-order page? I may pick one up and put the older 7" on the Z4 getting the GCs.
      08-23-2016, 02:27 AM   #15
Brule
Australia
827
Drives: 2007 335i e92 6spd man
How much?
      08-23-2016, 08:11 AM   #16
Tiago@VRSF
Tiago@VRSF's Avatar
2095
Drives: F90 M5
Originally Posted by E90gone View Post
Still no anodizing?
Not immediately, we have a lot of back orders to fill. Anodizing requires a few test units at a few local coaters/anodizing shops. We'll offer it shortly once the back orders are filled.
It's not available separately yet. We're waiting for them to arrive. The thing about the lower chargepipe upgrade is that it's only going to have guaranteed compatibility with our chargepipe since the coupler that joins the lower chargepipe to the upper chargepipe is no longer going to be universal. Won't fit with ER since the ER necks down to 2.5", won't fit with AA without a different coupler but it should fit the rest off the top of my head.
Originally Posted by Brule View Post
How much?
Click the link, unfortunately pricing can't be discussed here.
      08-23-2016, 05:18 PM   #17
DR-JEKL
Australia
898
Drives: Space Grey E92 335i 6MT
How much?
Looking fwd to your review
$720 usd and probably another hundred or so to darwin?
      08-23-2016, 10:23 PM   #18
E90gone
20
Drives: E90
Please keep us updated when this will be available. We have 3 test cars to run this on.
1.) FBO with PI manual with my custom Turbos (more info on the turbos shortly)
2.) FBO built auto (dynamics) with nitrous
3.) FBO auto ^^^^ going big single of the built tranny holds with nitrous and full e85
      08-24-2016, 07:31 AM   #19
Tiago@VRSF
Tiago@VRSF's Avatar
2095
Drives: F90 M5
The race intercoolers are expected to arrive on the 23rd of September unless you're referring to the anodizing. Do all three of those cars require anodized black intercoolers?
      08-24-2016, 10:10 AM   #20
Chris@VargasTurboTech
1933
Drives: All Things TurboCharged
Looks good! I may want to give it a go on my personal car.
Chris
      08-24-2016, 01:34 PM   #21
JTswole83
34
Drives: 335i
Dang lots of fast n54's in Tampa.
      08-24-2016, 09:36 PM   #22
E90gone
20
Drives: E90
We would like to have the best. As you know ever bit counts when you get to that power level. Plus, with all the heat down here it's hard to keep these car cool.
