08-21-2016, 05:34 PM | #1 |
76
Rep 181
Air vents occasionally blowing freezing cold air.
Been bugging me a while now,
Heater set to auto, 22c both sides, all vents open, centre vent temperature control set cold, recirc in auto. Cruising along all fine with comfortable face level airflow when suddenly the face level vents blow very cold for 2-3 minutes then all returns to normal. Same happens approx every 10-15 minutes after the first occurance which may not initially happen for 40 or so minutes. Nothing changed with any settings during the journey and no noticeable change to outside air temperature, level of sunlight or wipers being turned on. Just appears as a regular but random pulse of freezing cold face level airflow. This on a 2015 LCI F31. Anyone else had this happen as it is becoming annoying now? |
08-21-2016, 06:21 PM | #2 |
579
Rep 1,215
Happens to me as well, also used to happen on my old E91 too. I usually push the wheel to its warmest setting then gradually wheel it back again until it's comfortable.
08-21-2016, 09:15 PM | #3 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
Yea - mine does that too.
08-21-2016, 09:29 PM | #4 |
76
Rep 181
Annoying but at least no point in wasting time with the dealer.
Came from a 1 series--- no face level adjust wheel and the HVAC system was perfect, never had to fiddle, just left in auto to do it's thing except if defrosting ice first thing. A bit disappointing but guess I just have to live with it then. |
08-22-2016, 03:18 AM | #5 |
1867
Rep 13,043
Drives: BMW M340I G20
They do this from time to time. i think it's the HVAC system dealing with excess moisture.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
DarrenL_007208.50 |
08-22-2016, 03:26 AM | #6 |
234
Rep 738
Mine used to do this, but is better now!
I read on hear that there was a software update which sorted it I had trouble with my dash and the dealer said they'd updated the software. This did nothing for the dash problem but has helped the AC!! So I can only assume that there is a software fix for this!!
X3 M40i Carbon Black
08-22-2016, 03:57 AM | #7 |
12
Rep 30
Mine does the same - on a very intermittent basis (sometime not for several weeks).
Can’t work out why as does not appear to be linked to exterior temperature, sunlight, rain etc... |
08-22-2016, 05:47 AM | #9 |
741
Rep 2,511
Interesting thread. I've never had this happen in either my E90 or F30. However, for OCD reasons I like my dial centred...
Does this only happen when max cooling is selected for the face level vents? If so, could it be an icing issue, giving you max cooling until it ices up? Then defrosting and starting again?
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
08-22-2016, 06:13 AM | #11 |
849
Rep 1,858
i raised this issue on the forum in March
http://f30.bimmerpost.com/forums/sho....php?t=1239514 |
08-22-2016, 06:56 AM | #12 |
741
Rep 2,511
Sounds like the thermostatic action slightly lagging and needing to overcompensate. This is then amplified by user settings of the centre dial. Resulting in a blast of hot or cold air depending on the circumstances and settings.
08-22-2016, 07:47 AM | #15 |
1867
Rep 13,043
Really? he last three BMW's I've had have done this.
08-22-2016, 08:07 AM | #16 |
819
Rep 1,909
I noticed this on Sunday, as it was raining the bottom of the windscreen started to mist up but after a few seconds i could feel the a/c work its magic & the screen would clear up, i had the circulation button on AUTO, I'm pretty sure this is what its meant to do if you have the circulation on AUTO.
08-22-2016, 08:11 AM | #17 |
169
Rep 548
Drives: 2011 E90 M3 ZCP
Yep, my 2016 340i does this as well. I find that it happens with AUTO turned off and A/C turned off as well. So there is some sort of automagicness happening.
I'm assuming it detects some sort of moisture and quickly engages the A/C to deal with it? But that's just a guess so I don't actually have any idea. |
08-22-2016, 08:16 AM | #18 |
3489
Rep 9,709
The air con compressor 'cycles'. i.e it is not continuously running. It cools the evaporator down and then switches off until the system requires it to do its thing again. I'm thinking you are sensing when the compressor kicks back in and cools the evaporator, causing a sudden reduction in temperature.
This software update could just be reducing the tolerance of when the compressor needs to kick back in, effectively making it run more frequently with less of a delta in temperature. I would imagine that Ecopro would make this sensation worse as it supposedly reduces air on compressor function. |
08-22-2016, 12:55 PM | #19 |
Rep 71
08-22-2016, 01:37 PM | #20 |
47
Rep 201
My climate control is very much like a woman, i will never ever understand it.
gone but not forgotten, for the most part:
mondeo estate,A4 avant,elise S1,exige S2 190,exige S2 S280, 330D touring |
09-01-2016, 06:06 AM | #21 |
849
Rep 1,858
My car was in the dealer for a number of issues to be looked at and this was one of them - dealer has confirmed there is a software update to reprogram the A/C pump to address this issue - will get it done next week when car is in to get MAF, EGR cooler, fuel pump and 2 rear wheels replaced....
09-01-2016, 06:44 AM | #22 | |
17488
Rep 25,114
Hoping F15 is different HVAC system! |
