Two new gremlins. Any ideas?
08-19-2016, 09:04 PM | #1 |
2032
Rep 8,339
#1 My boost logged 28 psi, which is what it's supposed to be, for a few seconds then dropped to 21psi. We don't think I have a boost leak. Could this be boost solenoid? Poor vacuum?
#2my csr started overheating and showing s radiator symbol after drIvins 5 hours today. Mostly highway on cruise control. It has a new radiator, hoses, and pump. I did notice s wet spot inside the car on the drive tunnel carper under the dash by the passenger foot area. Idk if it's related. Didn't smell like antifreeze. I let the car cool for a bit then temps dropped some. Then driving it after temps continued to drop and not climb. The thermostat is broken open but I can't see that being the issue.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
08-20-2016, 05:55 PM | #4 |
2032
Rep 8,339
08-20-2016, 09:26 PM | #5 | |
135
Rep 1,075
08-22-2016, 07:43 PM | #8 |
49
Rep 270
Did the overheat symbol on (thermometer) or just the radiator symbol? If it is just the radiator symbol then you may have a leak somewhere as suspected but not overheating yet or if you cant trace the leak maybe the wiring came undone from the coolant tank?
08-23-2016, 07:15 AM | #9 |
2032
Rep 8,339
It did it in stages. First rad symbol. Figured small leak. Couldn't see anything. Heat stayed low where it belongs. Then a few hours later the overheat symbol.
08-23-2016, 12:04 PM | #10 |
49
Rep 270
Does it look like coolant came out from the expansion tank cap? If it didn't then maybe you might have an electrical glitch/error vs actually overheating. When the water pump fails or car decides it wants to overheat coolant will blow out of the expansion tank cap. I would get it scanned to see the codes.
