turbo replacement, inlets worth it if staying stock fuel?
08-18-2016, 02:24 PM | #1 |
13
Rep 245
hey guys
I need new turbos and I'm contemplating getting inlets right now I only have a jb4 and intake, but I'm getting downpipes too obviously the install of these 2 items (downpipes and inlets) will be free since the labor for turbos is already there.... I plan on keeping my car mostly stock other than the intake I already have, and getting downpipes. I was just wondering, should I bother spending the additional $300ish for inlets when I will not be flashing custom tunes, simply using the jb4, don't plan on doing too many mods in the future either... |
08-18-2016, 02:33 PM | #2 |
97
Rep 804
might as well do inlets along with the turbo install.... trust me you'll have an itch for more power later down the road.
E90 LCI M-sport/ 6AT/ LSD/ FBO+
08-18-2016, 02:57 PM | #3 |
13
Rep 245
yea, I say I dont want more power now but who knows tomorrow
which brand of stock location inlets are the best on the market? they'll be paired to my injen intake |
08-18-2016, 03:07 PM | #4 |
BimmerPost Supporting Vendor
24197
Rep 190,805
Since the turbos are going out i recommend getting inlets as well
Jonah33554.00 |
08-19-2016, 06:17 AM | #5 |
55
Rep 96
Just grab the mmp inlets and outlets if you can it will make your turbos work a lot less, or make a lot more power depending on what you wanna do
08-19-2016, 08:39 AM | #7 |
3441
Rep 79,211
Definitely recommend inlets on upgraded turbo's. Even if it's not about power, it's about efficiency. The turbo's can breathe so much better with inlets, which lowers WGDC, increasing efficiency and therefore your turbo's will work less to make the same power.
08-19-2016, 09:25 AM | #8 |
255
Rep 554
Drives: 2013 335is E93 6MT
If I ever need to get every vendor on the board in one thread pronto, I'll just put up a post with the title "Doing everything at once -- which FMIC, intake, DPs, charge pipe, inlets, and upgraded turbo should I get?"
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
TrollToll654.00 |
08-19-2016, 12:08 PM | #9 |
24197
Rep 190,805
But thats not what OP asked, not even close
08-19-2016, 12:18 PM | #10 |
2896
Rep 3,726
Why? I thought there were dyno proven gains...
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
08-19-2016, 01:50 PM | #12 |
421
Rep 1,643
Op said he's keeping his car "mostly stock", so the assumption is that means stock replacement turbos. While he may benefit with inlets, there's no reason to get outlets with stock turbos.
2007 E92 335i MT
08-19-2016, 04:38 PM | #13 |
423
Rep 900
Are inlets all about power or are they also proven to significantly increase the life of turbos? I recently had the opportunity to get inlets when I had my RB turbos out for a rebuild. I was not convinced that given my car is a daily driver with occasional free way bursts over the weekend to exercise her, I should get inlets. Already I feel the power the car has is a lot and just more than sufficient for a daily commute drive car. May be one of these days in the future I will regret the lost opportunity, but right now I simply don't see the point given my circumstances.
08-19-2016, 04:46 PM | #14 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
Inlets and outlets are small money imo. They will help even stock turbos. If you are in there you might as well do them.
terryd5150507.00 |
08-20-2016, 09:23 AM | #15 |
255
Rep 554
Just a little friendly chain yanking.
08-20-2016, 10:39 AM | #16 | |
387
Rep 1,571
I'd not concern myself with outlets TOO much; unless you are really going for utmost efficiency on upgraded turbos AND can find a high quality, well fitting, and nicely designed set of outlets. A well designed outlet will certainly offer a bit better efficiency for the turbo as well, but not nearly at the levels of inlets. The install of outlets are much easier to service, or with turbos already in place. In short Inlets are where it is at, these days with the availability that exists you just simply do them without question. Rob |
08-20-2016, 11:35 AM | #17 |
318
Rep 516
Inlets have been proven many times on even stock turbos to gain 35-45whp
MMP outlets have been proven a few times to make gains as well on stock turbos. MMP outlets are the only 2" outlets on the market. Here is the latest review and dyno gains for outlets posted here http://www.e90post.com/forums/showthread.php?t=1290781 This user gained 24whp on stock turbos with outlets keeping boost the same. Results speak for themselves. |
08-21-2016, 04:07 PM | #19 |
654
Rep 946
