Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Can someone please help me, I might have the strangest N54 issue
      08-18-2016, 11:24 AM   #1
Miller335
291
Drives: 2007 E92
I have what I call a "bump" or a "thump" when going WOT and RPMs climb.
My logs look near PERFECT. The only thing that is even a clue in the logs is the rpms DROP ever so slightly while this "bump" happens.
Look at the log around 4k rpms in this log and you'll see it happening.
Does anything else in the log stand out?
I've changed plugs and the issue persisted.
I ditched stock DVs to a Tial BOV and still the same.
I've tried various MHD tunes, still exists.
Seems to be only under high load/lows rpms, as soon as rpms get over 4k or so it never happens.
At my wits end, car runs perfect otherwise, no misfires or codes.
Can someone please help?
Log: http://www.datazap.me/u/miller335/71...og=0&data=4-22
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
      08-18-2016, 11:33 AM   #2
Msport335
Msport335's Avatar
97
Drives: 2009 335i m-sport e90
most likely a slight loss of traction/bump in the road
E90 LCI M-sport/ 6AT/ LSD/ FBO+
      08-18-2016, 01:16 PM   #3
Miller335
291
Drives: 2007 E92
All traction aids off and road is 100% smooth.
      08-18-2016, 01:19 PM   #4
V8bait
406
Drives: e92 335i 6mt
How long since you had your valves nutted on?
TrollToll654.00
      08-18-2016, 01:20 PM   #5
theweebabySeamus
376
Drives: M3
+1
Or coils. Probably not but you never know.
      08-18-2016, 01:34 PM   #6
Miller335
291
Drives: 2007 E92
10k miles ago
      08-18-2016, 01:37 PM   #7
Miller335
291
Drives: 2007 E92
Originally Posted by theweebabySeamus View Post
+1
I'm going to clean vanos solenoids when I change my oil in a few weeks also.
Probably wouldn't hurt to change coils but no misfires or nothing.
I hate just throwing parts at the car blindly though.
      08-18-2016, 02:14 PM   #8
wren57
Roll Tide
wren57's Avatar
591
Drives: 335i
Solution: downshift.
Cost: $0.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306
      08-18-2016, 02:15 PM   #9
2011z435is
55
Drives: 2011 z4 sdrive35is
there is a throttle closure right where you are talking about, probably related to that.
      08-18-2016, 03:05 PM   #10
Miller335
291
Drives: 2007 E92
Good catch!
What do you think would cause this?
      08-18-2016, 03:14 PM   #11
mojobmw_e90
380
Drives: 2014 E63S
Originally Posted by Miller335 View Post
Good catch!
I remember Terry talking about how the ecu manages fuel by shutting the throttle down to compensate for ignition timing regardless if ur foot was 100% on the pedal
      08-18-2016, 03:18 PM   #12
FCobra94
Guest
n/a
Drives:
There's definitely something wonky going on in between 4021 and 4215 rpm, not related to throttle closure. AFR between the two banks goes wacky, then recovers.
I've heard of new primary O2 sensors fixing similar issues during low load situations, but not sure if a new set will help you here. Interested in hearing what the more knowledgeable members have to say though
      08-18-2016, 04:18 PM   #13
cstmx_ryder
cstmx_ryder's Avatar
164
Drives: A metal box with a roundel
Have you switched back to stock tune? Try that and see if it still happens.....
'08 AW E90 335i
PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10
      08-18-2016, 05:27 PM   #14
Miller335
291
Drives: 2007 E92
I've ran an agrressive pump gas tune and it doesn't happen.
Only when I run an E85 does it seem to happen.
      08-18-2016, 06:38 PM   #15
Chromey
Chromey's Avatar
98
Drives: 09 E93 M3
I had a hiccup and it was a leaking injector.. Ran lean then dumped rich , felt like a mis ...
Appreciate 2
      08-18-2016, 08:48 PM   #16
Miller335
291
Drives: 2007 E92
That's exactly how describe, like a miss./hiccup.
      08-18-2016, 09:20 PM   #17
Julian2485
110
Drives: Black lci e90 335 xdrive
Are you xi and manual or auto ?
      08-19-2016, 09:01 AM   #18
Miller335
291
Drives: 2007 E92
RWD 6MT
      08-19-2016, 10:10 AM   #19
Miller335
291
Drives: 2007 E92
Did u have other symptoms?
Or just this WOT issue Im also having?
      08-25-2016, 02:31 PM   #20
Miller335
291
Drives: 2007 E92
Any other causes for this other than injectors?
Doesn't seem to have this issue on pump gas.
I don't want to spend over $1k on injectors for it to be a maybe fix.
8Series12.50
      08-25-2016, 03:36 PM   #21
335is-dct
184
Drives: 335is
weird. i definitely see the rpm bump and corresponding fluctuations in boost. could be coils or maybe switch out to a different plug.
i do however see that your lpfp is taking a big hit immediately prior, dipping down to about 50psi, but i'm not sure if its related. you mention this "bump" only happens on e85, so it may have something to do with the increased fueling demand. might be time to invest in a new pump.
      08-25-2016, 04:48 PM   #22
Miller335
291
Drives: 2007 E92
I have a stock pump and a walbro 255 inline, what should I jump up to you think?
