Jumping ship from hybrid to Single! Questions...
08-18-2016, 07:23 AM | #1 |
63
Rep 605
What's going on everybody? I've been contemplating for some time now on either going with the MMP stage 3 turbo route, which has recently had some mechanical defects, or the JP Workz ST. With all the You Tube videos I've watched and my first hand experience, in a single converted 335i, I'm sold! :happy I've finally decided to do the big single with either a 6266 or 6466, but that's more to follow. I have a few questions before I do make my purchase.
What are some of the common issues faced with a single conversion? What is an average cost to get the kit installed? Is there any additional precautionary equipment I would need in order for a safe install/ safe guard any known issues? Lastly what housing should I use and what is the difference in each i.e .63 A/R, .85 A/R, etc? From what I've come up with it seems that a single kit has a one point failure, the turbo, compared to the hybrids. I know there has to be more than that, but I haven't found anything else. I've had my fair share of smokey hybrids and if one went bad then the other is bound to follow. In the event that the turbo went bad, I could easily pop that one off and put a new one on compared to the hybrid setup. Thanks!
F90 M5 Comp/ FI Exhaust, MAD pdownpipes / PG Intakes/ H&R Springs/ AG wheels
E85 Z4M Last edited by Shadow007; 08-18-2016 at 07:39 AM.. |
08-18-2016, 08:30 AM | #3 |
135
Rep 1,075
I think the actual turbos are more reliable in the single turbo kits, and they are much easier to switch out... But the singles have their fair share of problems.
I have seen melted engine covers, valve covers and A/C lines. There has been a lot of o2 sensor issues as well. Not to mention over all fitment issues. (But most of the kits have worked this problem out) Make sure to use heat wrap, heat tape or ceramic coating. |
08-18-2016, 02:58 PM | #5 |
318
Rep 516
The MMP stage 3 just had a weld on the first batch that welds the nut onto the bearing housing that was a little thin. All stock has been corrected now and won't be an issue going forward.
08-18-2016, 03:07 PM | #6 | |
2134
Rep 3,554
And not sure who told you they dont run right... They have been doing very well in terms of performance. OP, the biggest issue right now, which is an issue for every single, is the O2 sensors. Do some research on that before you move forward. I believe a solution is in the works or out now for them. |
08-18-2016, 04:23 PM | #7 | |
71
Rep 394
08 E82 135 -jpworkz 6870 top mount built motor
10 E92 M3 - Ess 650 Supercharger 18 BMW 530e - stock |
08-18-2016, 05:39 PM | #8 | |
63
Rep 605
E85 Z4M |
08-18-2016, 05:47 PM | #9 | |
2134
Rep 3,554
Theres a lot of info on the more technical forums. |
08-18-2016, 05:57 PM | #10 |
102
Rep 416
I was in the same boat and decided to go MMP S3. The reason I decided against the ST was the lack of connection between the downpipe and stock style exhaust with the JPW kit and the lack of boost control using flash only without going JB4.
08-18-2016, 06:50 PM | #11 |
63
Rep 605
Hmm I have a 3 in exhasut from the cats all the way back and I'm using jb4 with a BEF. I'll switch to,mhd once I do make the switch.
08-18-2016, 07:55 PM | #12 |
71
Rep 394
You do not need a JB4 to control boost with a single turbo. There are alot of guys running MHD flash with a electric boost controller.
08-18-2016, 09:42 PM | #13 |
102
Rep 416
So the DME is not controlling boost, you still need a standalone boost controller?
The ST does look bad-ass, but I went for what I thought would be the best option for me. The power should be similar but come on sooner in the RPM range. |
08-19-2016, 08:02 AM | #14 |
34
Rep 95
08-19-2016, 08:04 AM | #15 |
34
Rep 95
You use an EBC to control boost if you are flash only.
08-19-2016, 10:18 AM | #16 |
192
Rep 1,173
08-19-2016, 07:13 PM | #20 | |
71
Rep 394
