335i N54 Turbo to Down pipe Gasket - Does it exist?
08-16-2016, 04:54 AM | #1 |
Rep 15
I fitted some de-cat Down pipes at the weekend, all went well except for when I drove away and accelerate hard. I can hear some kind of blowing / rasping leak coming from the front of the car. Can I just add that fitting down pipes is no simple 4 out of 10 difficulty task - it's a bag of dicks of a job, took us 8 hours - we are not mechanics.... Anyways - I took my car to my local mechanic and he said I need new clamps that connect the down pipes to the turbos as they're worn and not tightening up correctly. At this point I wondered if it was a gasket problem and checked online (even though I do not recall even seeing one when we did the DP swap). I asked him if it was the gasket and he said it is a dry seal (no gasket). So I did some searching and it seems some people think there is one, and some people think there isn't. Can someone please clarify?
08-16-2016, 07:52 AM | #3 |
Guest
Rep n/a
Drives:
Dichtung Turbolader/Katalysator
theweebabySeamus376.00 |
08-16-2016, 08:03 AM | #5 |
48
Rep 263
Yes there is a gasket it sits inside a recess in turbo exhaust housing https://www.turnermotorsport.com/p-2...-s63n-engines/
UK
V8bait Tuned Built motor FBO 335i |
08-16-2016, 09:13 AM | #6 |
100
Rep 1,040
I've done two sets of downpipes and I don't recall a gasket on the v band side, only on the exhaust side...
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
08-16-2016, 09:23 AM | #7 |
38
Rep 144
In my opinion I'd find a new mechanic. I've had my downpipes on and off 20+ times on my old 07 the clamps never wore. In my opinion only thing that can happen is they break from trying to open them too wide. The way you can tell if your downpipe is positioned correctly is when you slide your clamp over the downpipe flange grab the two tabs where the bolt goes in and squeeze them. If positioned correctly you can almost squeeze the two tabs together. If not positioned correctly the clamp will be very hard to meneuver and won't be able to squeeze it with your fingers very much at all. In this case you can have small exhaust leaks, if you put car on ramps and slide under while running you can hear it or feel the air puffing sometimes. Hope this helps, good luck!
Dommyem9.50 |
08-16-2016, 02:35 PM | #8 |
326
Rep 613
This thread came at a perfect time, as I've just bought a set of DP's.
Should I pass on buying these turbo-to-DP gaskets? https://www.ecstuning.com/BMW-E90-33...E/2/ES2800268/ I've read all the tutorials and watched some DIY videos, and none of them mention replacing any gaskets at that location.
2009 E90 335i
Black Sapphire || Oyster || M-Sport || 6spd BMW-Performance||OEM+||Cobb||Wagner||CP-e||AFE||Forge||ER||BMS||Lux||RB||Bridgestone||Manz o||Bilstein||Eibach||Whiteline |
08-16-2016, 04:16 PM | #9 | |
Rep 177
08-16-2016, 04:18 PM | #10 |
326
Rep 613
Fair enough. I just bought a set just to have, in case I do damage them.
Better to be safe than sorry, especially at only $20 for the pair Thanks!
2009 E90 335i
08-19-2016, 03:09 AM | #11 |
Rep 15
FOUND IT! It hides in the turbo. Its barely visible when fitted.
Gasket: View post on imgur.com Gasket fitted: View post on imgur.com removed: View post on imgur.com Can see it here: http://www.realoem.com/bmw/enUS/show...diagId=18_0681
2007 335i E92: JB4-G5, Mishimoto FMIC, DP's, DCI.
08-19-2016, 09:01 AM | #13 |
31
Rep 136
I've done DP a few times on 335i. Just to reiterate and confirm what others have said. The DPs have gaskets at both ends. You probably will not need to replace the gaskets at the turbo end (as long as you're careful and don't damage them). The gaskets that connect to your midpipes will need to be replaced.
Ok, so your VBand. You need to make sure you can close the tabs the bolt goes through. If you find that you're tightening the VBand really hard, you feel like you're about to break it or strip it, yet the two tabs have a 1/2 inch gap and aren't going to close, then you have a problem. Or if you feel like the stock screws are not long enough. You have a problem. The problem is the vband is not correctly seated, and it's probably in the back of the connection and you can't see it. It's not correctly around the flange. For me, if I just can't jostle the VBand clamp to get it to seat, I remove the vband, pull the downpipe away from the turbo. Take a deep breath, then try again. Fit it all up there together, but this time keep in mind to really make sure the back of the VBand clamp is correctly seated over both flanges. Then you should be able to tighten the VBand and get the two tabs close together or touching without feeling like you're going to snap something.
2010 335i Coupe E92 N54. JB4, Burger dual cone air intakes, ER chargepipe with Turbosmart blow off valve, AMS intercooler, catless downpipes, Koni yellow shocks and struts with H&R springs. Stoptech rotors, pads, and lines, KMC691 bronze in 19" 35mm offset, Pilot Super Sports 235/35/8.5 and 265/30/9.5, LED angel eyes, EL interior accent lighting,Stereo (Helix DSP, Arc Amp, Jehnert subwoofers, Morel woofers and tweeters), Formula1 tint.
08-19-2016, 09:15 AM | #14 | |
mTekMods
2142
Rep 2,902
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
