Boost gauges
08-16-2016, 03:41 AM | #1 |
4542
Rep 11,903
Boost gauges
What boost gauge options are out there???
For example there is the Arwon (expensive and doesn't work with tuned cars) ECS vent gauge (angle of the vent bracket is only good for LHD) JB4 gauge hijack (accuracy?) MHD via phone (not really an integrated solution) Anyway none of these are a great solution IMO... What set ups are peeps running and what options are out there |
08-16-2016, 03:57 AM | #2 |
Lieutenant Coal Burner
161
Rep 1,639
08-16-2016, 04:29 AM | #3 | |
4542
Rep 11,903
08-16-2016, 04:54 AM | #4 |
541
Rep 3,131
Drives: 2011 335i e92 DCT
JB4 works fine, its responsive and also can show boost and your last high boost.
It holds your last high boost so you can go WOT and not have to be looking over at it, you can slow down then look and it stays there till the next big boost replaces it. At least I think thats what it did, I used it, thats all I could gather it was doing
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
08-16-2016, 04:56 AM | #5 | |
541
Rep 3,131
I think it lugs into OBDII though which is ugly.
08-16-2016, 05:06 AM | #6 |
541
Rep 3,131
Actually you can put the ODB cover back on, its pretty clean
Socket4542.00 |
08-16-2016, 05:34 AM | #7 |
37
Rep 241
Yeah the P3Cars in-vent digital gauge is awesome. I had one back in my Audi days and can vouch for the quality and OEM look and feel. Doesn't look tacky at all
CARS:
2016 BMW F31 340i M SPORT - FAMILY EXPRESS Sold - 2006 BMW E92 335i - WEEKEND WARRIOR Sold - 2003 BMW E39 530i M SPORT - CLASSIC Q Sold - 2004 AUDI B6 S4 AVANT - THE UNICORN |
08-16-2016, 05:46 AM | #8 |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
P3's do not work with JB4's.
I use the JB4 mobile app gauge, the only thing that bugs me about the boost readings is that it shows a little over boost in the readings. |
08-16-2016, 05:52 AM | #9 |
37
Rep 241
Aw dang. I wonder if it'll play nicer with MHD
CARS:
08-16-2016, 06:52 AM | #10 |
4542
Rep 11,903
08-16-2016, 07:03 AM | #11 |
1495
Rep 3,148
P3s work with piggybacks, you can get a version that you run a hose from the intake manifold to the gauge. I previously had a Procede and previous owner ran a P3 gauge in my car
08-16-2016, 04:41 PM | #13 |
73
Rep 455
p3 via obd you can't use jb4 also will only work with 08+ models (pre 08 don't have can H and can L on the port). They do sell a boost and battery for non obd installation, but its a lot of coin for a boost gauge.
OBD version has Code Read/Clear, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more! |
08-16-2016, 07:32 PM | #14 | |
37
Rep 241
CARS:
08-16-2016, 11:16 PM | #15 | |
619
Rep 3,021
08-17-2016, 03:29 AM | #17 |
77
Rep 541
Drives: 2008 135i AT Monaco Blue
I have the P3 gauge setup (v2.3) running via OBD port and also have the hose running into the engine bay for more accurate readings. I'm Cobb tuned and no issues with the P3. It is excellent and very stealth (looks factory). You can read so many parameters, view last max boost value, view & clear codes etc. Highly recommended.
I assume it would work with MHD as that's just a flash using the same principle as Cobb.
08-17-2016, 06:02 AM | #18 |
619
Rep 3,021
If only P3 made a cheaper, boost reading only option.
08-17-2016, 06:31 AM | #19 |
619
Rep 3,021
08-23-2016, 03:09 AM | #20 |
898
Rep 6,285
08-24-2016, 09:51 AM | #22 |
128
Rep 451
I like my ECS guage. It was the only one that didn't cost a fortune. I thought I saw they have a RHD mount but I drive on the proper side so didn't pay it much attention.
