Bad JB4 Board?
08-15-2016, 10:07 AM | #1 |
100
Rep 1,040
Bad JB4 Board?
Just had my motor replaced from a rather epic block explosion and all is put back together and ready to go, but a vac test is showing normal vac before the solenoids and no vac after the solenoids. Just updated the JB4 to the latest firmware, flashed the car back to stock, tried two different sets of solenoids with the same issue. Terry mentioned that it could be a bad board or power wire, but the board worked find prior to the swap. First time I've had this issue in over three years with JB4. Pulling the JB4 tonight to see if the issue still persists, but has anyone else experienced this? Also, VRSF inlets were just installed with the motor. Tried both with the vac canisters and without.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
08-15-2016, 12:15 PM | #2 |
2134
Rep 3,554
my 1st thought would be to see if its the JB4 or the solenoids. See what happens when you remove the JB4.
Are you able to switch maps and get into the jb4 menu from steering wheel or connect via USB? |
08-15-2016, 12:26 PM | #3 |
100
Rep 1,040
Yeah, steering controls worked fine and I updated the firmware. JB4 will be pulled later to check. I have two sets of solenoids and both do the same thing.
08-15-2016, 12:27 PM | #4 |
456
Rep 6,478
The small screws to the AMP are trash in my humble opinion. Over time the connection gets frayed/bent/etc and goes bad. I had it happen to me twice in 9 months and ran out of patience before buying a third unit.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
08-15-2016, 12:50 PM | #5 | |
100
Rep 1,040
When that happened to you, did you have similar symptoms? Figured a bad board would make it so I couldn't update the firmware or really have any JB4 function at all.
08-15-2016, 06:26 PM | #6 |
456
Rep 6,478
Yea; the JB didn't have power so wouldn't turn on.
08-15-2016, 10:09 PM | #7 |
100
Rep 1,040
08-16-2016, 09:28 AM | #8 |
456
Rep 6,478
They fail at a disconcerting rate in my opinion.
08-16-2016, 09:32 AM | #9 |
100
Rep 1,040
Well, first one bad in three years so I guess that is a good streak. Really hoping this was not the root cause of my engine exploding... At little concerning considering this was discovered as soon as the new motor went in after previously working fine.
08-16-2016, 02:18 PM | #10 | |
456
Rep 6,478
I doubt the JB caused you to lose the motor. Still, it's frustrating that such an important piece of the puzzle is held together by such cheap parts.
08-16-2016, 02:48 PM | #11 | |
100
Rep 1,040
09-13-2016, 02:08 PM | #12 |
100
Rep 1,040
Turns out the shop who replaced my engine did not connect the power wire properly. The power wire was connected to the meth power wire and installed wrong. I pulled the meth wiring out completely and reinstalled the JB4 and it worked perfect. Sent the board out to be verified by Terry and all was good... The one time I actually have someone else work on my car is for sure the last.
