Leaky injectors question
08-14-2016, 10:17 PM | #1 |
97
Rep 804
I suspect I have 2 leaky injectors due to a cold start misfire. Car now has new coils and plugs.
Can I purchase 2 used but good index 6 injectors to swap out the 2 that are leaking ? Coding is still a requirement ?
E90 LCI M-sport/ 6AT/ LSD/ FBO+
08-14-2016, 11:41 PM | #2 | |
197
Rep 1,070
You might find two rebuilt index 6, or could swap 3 new index 12 into the bank with bad injectors. Might check rock-auto for prices and availability. They are over $200 at the dealer.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
08-15-2016, 02:09 AM | #3 |
327
Rep 960
yes coding is required. it's required even if you switch the injectors (e.g. swap cyl 1 with cyl 2).
I wouldn't bother with used injectors they will just fail again. |
08-15-2016, 07:49 AM | #4 |
207
Rep 602
Anything index 10 or less will be fine and yes they need to be coded. For the simple fact that they take 10 minutes to swap I don't mind swapping a bad one for a good used one.
08-15-2016, 08:51 AM | #5 | ||
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
08-15-2016, 01:03 PM | #6 |
100
Rep 1,040
Not 100% on this, but I think that it is recommended that you replace the whole bank (3) as opposed to just pulling two. But, yes, coding is required. There are a few indexes that are interchangeable too.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
08-16-2016, 12:09 AM | #7 |
28
Rep 42
You only need to replace them by bank (3 injectors) if you are using above index 10 as was stated above by CanadianTsi....who I assume is a former DSMer like myself
