Ever since I updated jb4 my car went to shit.
08-13-2016, 06:41 PM | #1 |
Rep 49
I updated jb4 last december and ever since I have been getting low boost codes and engine malfunction. I've had the car checked several times and nothing wrong was found. How do I completely revert any changes jb4 made and disable all settings to factory settings, and then do a complete uninstallation? Is there a guide? I didn't install it so I don't know where to start.
08-13-2016, 06:56 PM | #2 | |
47
Rep 1,173
This is stock OEM map. - Which firmware are you running? The latest I believe is ISO 5.11. - When you updated, did you update your User Adjustment settings? There is a screenshot of what the default settings should be with the latest firmware (on N54Tech). - Do you have the USB data cable, or bluetooth module? |
08-13-2016, 09:52 PM | #4 |
Joint Chiefs of Staff
4918
Rep 115,980
Sounds like you set something wrong. It's all pretty basic. Directions and FAQ is posted here:
http://www.n54tech.com/forums/showthread.php?t=10605 Double check settings. Also as a thought perhaps you did not set duty bias values all to 0 and/or did not set menu4 in dash to 3. You can post a JB4 log to the n54tech support forum for advice on what you've done wrong if you need. Mike |
08-13-2016, 10:15 PM | #5 | |
75
Rep 168
08-14-2016, 01:52 AM | #6 | ||
Rep 49
I did a few pulls and the first run it knocked me into map 4 and then I went again and it seemed fine, but seems to be some boost loss. Also all of my controls lit up break, service engine, abs, chassis malfunction, DCS malfunction, startup control deactivated. I tried pulling codes from the OBD with the map on 0 and couldnt even connect. JB4 gave me 3 codes that aren't listed anywhere. "2fe4" "2f60" "2f5f". Car also automatically shifts into second from first at around 3.5-4k rpm in manual mode (2013 335is e93 DCT) I haven't gotten an engine malfunction warning yet (this comes up sporadically), but it did knock me into map 4. View post on imgur.com I uploaded a few pics of the settings i had, switched all duty bias to 0 and then max boost 3rd to 0 then did the runs Last edited by Mayan; 08-14-2016 at 02:01 AM.. |
08-14-2016, 02:02 PM | #8 |
2134
Rep 3,554
Read through the link posted earlier. All the info you need to set it up correctly is there.
And if you are having issues in map 0, then it's a problem with the car, not the jb4. How's your plugs, coils, injectors and fuel pumps? Those are the first things to check |
