03-27-2008, 12:18 AM | #1 |
134
Rep 1,709
Cost of coilover install...
Would like to know how much you spend on the install of your coilover system, and anything to watch out or replace...TIA
Live as if you will die tomorrow, but learn as if you will live forever." M.G
03-27-2008, 02:45 AM | #2 |
74
Rep 1,689
$250 (for a coupe, roadster most likely more)
Check out Rogue Engineering for some rear shock mounts. This is beneficial that it replaces a weak part of the suspension and any subsequent mods to the rear suspension won't require you to tear up the trunk. It replaces the weak factory mounts with some nice billet pieces as well it converts the nuts to bottom mount instead of top mount. http://www.rogueengineering.com/Merc...ategory_Code=S And if you plan on slamming the car, you'll need adjustable control arms for the rear so you don't get excessive camber. http://www.uucmotorwerks.com/CHROMOLY_ADJ_ARMS/ Front camber can also be taken care of as well: http://www.uucmotorwerks.com/suspension/camber/ If you're not gonna bother with the other UUC mods (gets really pricey), I highly recommend at least doing the RE shock mounts. If you're putting in suspension this is one of those must do mods at the same time. And thanks for posting where it belongs!
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5 Once upon a time... '03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T Last edited by pbdm4k; 03-27-2008 at 10:30 AM.. |
03-27-2008, 02:34 PM | #3 | |
134
Rep 1,709
Thanks...I will email RE and try to get those parts...
03-27-2008, 03:23 PM | #4 |
61
Rep 1,210
Roadster will be substantially more, getting to the top strut bolts requires removing the soft top tray assembly, an additional 30 minutes possible per side.
03-28-2008, 03:51 AM | #5 |
134
Rep 1,709
thanks...I will be also upgrading to the adjustable rear lower arm...
03-28-2008, 03:54 PM | #6 |
74
Rep 1,689
Are you going to go with the UUC arm? Or an eBay special?
2006 VW Jetta 2.5 Once upon a time... '03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T |
03-29-2008, 01:48 AM | #7 |
134
Rep 1,709
I'm not sure yet...i'm still researching on which one to get...any recommendation?
03-31-2008, 03:03 AM | #10 |
134
Rep 1,709
Can you post the link...thanks
04-01-2008, 05:47 PM | #12 |
John 14:6
59
Rep 587
If anyone's interested in a camber kit, Eibach makes one for a very reasonable price. Let me know, I know someone in LA that can sell you the part and install for < $300.
04-04-2008, 02:32 PM | #13 | |
74
Rep 1,689
Two very different things!
04-04-2008, 02:33 PM | #14 |
74
Rep 1,689
Yeah, the UUC ones look really beautiful, but the cost is hard to justify.
04-11-2008, 02:18 AM | #15 |
74
Rep 1,689
07-07-2008, 11:51 AM | #16 |
16
Rep 385
GC's rear arms are great, and less expensive than UUC's: http://www.ground-control-store.com/.../II=655/CA=103
They also have rear shock mounts: http://www.ground-control-store.com/...php/II=8/CA=11 |
07-09-2008, 12:41 AM | #17 |
12
Rep 118
You won't need the adjustable arms Chris ... I'm pretty sure I have the lowest Coupe I've seen yet and my alignment was perfect (Thanks to BMS!) with no extra additions.
I do however agree to get the Rogue rear mounts. |
07-21-2008, 01:21 PM | #18 |
1820
Rep 5,337
You should look into the rear adjustable arms if you intend to use the car for track, unless you're prepared to buy a new set of tires every 3-4 events (or learn to drive conservative enough to not burn through the outside of the tires).
07-21-2008, 01:28 PM | #19 | |
16
Rep 385
