M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      08-11-2016, 12:03 AM   #1
jensputzier
Germany
99
Drives: 2018 F90 M5
DCT loses oil
Just a quick note:
My car is 18 months old now and I noticed a small drop of oil in the driveway after parking. The car went to the dealer anyway that day (front LED turnsignal broke) and they discovered that the seal of the DCT oil sump was leaking. They had to refill about 0.4 liters of oil. Gearbox contains 8 liters and DCT was behaving normal, so nothing mich happened. But you might want to check on your car just to make sure.
HAZET Stahlwille Knipex German tools shipped worldwide.
http://www.jensputzier.com
      08-11-2016, 03:13 AM   #2
CSL335i
Hungary
207
Drives: M2 and...
Originally Posted by jensputzier View Post
Just a quick note:
This is a common problem on AT and DCT tranny. I suggest you to change the oil sump and related stuff (oil, filter, etc). The root of this problem the heat itself. After a period of time, the oil sump (as it is made of plastic) will have a kind of deformation and getting leaking.
      08-13-2016, 06:23 PM   #3
Used2be
Perennial PFC
Used2be's Avatar
336
Drives: F90 M5 DG/Aragon
Perhaps this is why, at least in the USA, you have to buy the DCT sump to obtain the gasket for the sump. BMW in its wisdom does not sell the gasket for the DCT sump separately. The sump and gasket cost $201.89 USD from my dealer. I am considering buying an aftermarket metal DCT sump, and it looks like buying the stock sump is the only way to get the gasket! I suppose if I do get the metal sump, I'll disassemble the stock sump first and hope the gasket will be reusable.
      08-13-2016, 06:47 PM   #4
momos750
momos750's Avatar
143
Drives: 2015 M5, 2011 750Li
I asked my service advisor about maintenance on the DCT and he advised me there is no recommended service or fluid changes.
Apparently the fluid is suppose to last the life of the transmission. :
2015 M5 - Singapore Grey Metallic - Silverstone Full Merino Interior - Executive Pack - Drivers Assist Pack -Comp Pack -
      10-05-2016, 08:19 AM   #5
jensputzier
Germany
99
Drives: 2018 F90 M5
Now, 6 weeks later I went to BMW to have them look over my brake pads (2.200kms left before a longer trip). Brake pads are good, but the complete underside of the car is again full of DCT oil leaking. Not good....
      10-11-2016, 08:52 PM   #6
TrevorM3
3322
Drives: 6.3 AMG
they need to replace the housing it sounds like?
      11-05-2016, 05:17 AM   #7
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
The metal case from Ssp will solve your issues
http://sspperformance.shopgate.com/item/3437
m5post
