BMS Meth Kit Problem
08-10-2016, 03:21 PM | #1 |
Rep 50
I'm having trouble with my installation and I double checked everything. Now, my car won't start so not sure what's the problem. Here are some pictures of my install. I have an N54 so Blue wire goes to Spot 15 and orange goes to spot 2. I have the big red wire on FSB going to red wire with fuse and on the other hand I have a black solenoid wire and red wire that routes to the waterpump. Black waterpump wire grounded to the trunk. Any help is appreciated, Thanks!
08-10-2016, 04:32 PM | #6 |
Joint Chiefs of Staff
4918
Rep 115,980
08-10-2016, 04:35 PM | #7 |
BimmerPost Supporting Vendor
24198
Rep 190,805
Did you send the pictures to BMS technical support?
08-10-2016, 05:02 PM | #8 |
Rep 50
I had a loose wire that was not connected to anything near clutch when I removed the under tray to put the wires through the firewall. Do you have a picture of a clutch wire? yes, I email pics to the bms tech support. Is this the clutch wire?
08-10-2016, 05:33 PM | #9 |
Rep 50
I tried snapping that piece back above the clutch where it seemed it should fit. Car started! Thanks MIKE!! Can't believe that little piece can be sucha pain in the ass. I can't really see how it attaches to that spot but I just pushed back into the slot. Will it come loose again?
08-10-2016, 06:04 PM | #10 | |
4918
Rep 115,980
Mike |
08-10-2016, 07:14 PM | #12 | |
93
Rep 605
08-11-2016, 06:16 PM | #15 |
Rep 50
I ran my pump ground to the negative battery still no luck. The red light turns on the FSB but I don't hear pump still. Anyone from Chicago area? I'll buy you dinner and beer.
