19x9 ET 39 square set up on E90 LCI front tires?
08-10-2016, 01:06 PM | #1 |
Rep 33
Hey everyone, I'm a bit of a noob here and starting to do stuff to my BMW for the 1st time. Although I've previously owned a BMW before, this is the first time I'm modding a BMW. So I was hoping I could get some help from you guys. I have a E90 LCI and looking to mount square setup 19x9 with an offset of 39. I know in the back it's 255/30/19 but what about the front? Can I run the same size?
The car will be lowered on H&R sport springs. I've searched the forum and online but didn't find anything concrete. Closest result I found was people running 18x9 square set up with 255/35/18 all around. But those are 18's and I'm mounting 19's. But any help is much appreciated. Thank you in advance. |
08-10-2016, 02:34 PM | #2 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Just going to say a 255/35/18 is the exact same size (externally) as a 255/30/19. Not going to comment about the front fitment on your LCI since I think pre-lci fitment is slightly different which is what I have.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
08-10-2016, 02:55 PM | #3 |
Rep 33
I know the rear-ends of the LCI's have about an 8 mm wider track from what I read but fitment shouldn't be an issue on the rear. Just the front I'm concerned about. If it is the same as pre-LCI's then I should be good as you are another example of someone running a square set up with 255's. From what I've read, LCI and pre-LCI are the same in the front, just the rear has a wider track. Hopefully someone can help answer that. Do you have any rubbing issues by any chance? thanks for the reply by the way.
08-10-2016, 08:10 PM | #4 | |
1552
Rep 3,475
08-10-2016, 09:54 PM | #5 |
91
Rep 254
Running 255/35/18 PSS fronts on 9" ET30. Lowered on ST-V1's. I rub on large bumps at higher speeds. Hoping to pull my alignment pins to get a little camber and get rid of the rub.
08-11-2016, 07:51 AM | #6 |
Rep 33
Seems like it should work then. My only concern is that the offset is 39 so I don't know if it will rub against the suspension. But seems you guys have slight rubbing issues towards the outside with lower offset's. So I'm thinking it should be okay. Thanks for the help everyone.
08-11-2016, 08:48 AM | #7 | |
1552
Rep 3,475
08-24-2016, 12:53 PM | #8 |
28
Rep 92
et39 is too much for the front, you'll need at least a 10mm spacer, if not more depending on what tire you want to run. For anything fatter than 255 you will also need about -2 degrees to clear the front fender, exact amount dependent on how lowered you are.
Rear fitment should be fine, maybe a small (3-5mm spacer) depending on the tire and how flush you want it |
08-24-2016, 07:43 PM | #9 | |
453
Rep 2,973
Rear is nothing for a 9". I'm also running 19x9.5" ET33 APEX EC-7 Wheel in the rear with 275/30-19. No issues. Fenders not even rolled.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
